leaking water pump. really need help!
nyantong
192
50
Firstly, where is it leaking from? If its from the gasket seals around the water pump body, you can use rtv sealant to re-seal the water pump.
However, if it leaks from the pulley bearing, I'm afraid you will have to change the entire pump.
just change the waterpump if the pump already leaking....
Once water pump starts to leak better change. Work to take out also will take time....
hi guys. i have seen quite a number of perdana's either running on 6a12tt or evo3 engines, but is it possible to fit in a e4 and abv on the engine bay?
