leaking water pump. really need help!
nyantong
192
50
Firstly, where is it leaking from? If its from the gasket seals around the water pump body, you can use rtv sealant to re-seal the water pump.
However, if it leaks from the pulley bearing, I'm afraid you will have to change the entire pump.
just change the waterpump if the pump already leaking....
Once water pump starts to leak better change. Work to take out also will take time....
HI To all,
I'm Just curios about port and polishing-
-Hows it the petrol consumption -Some say hi some say low?
-About the performance difference wat is the ratio or percentage of increase?
Any one of u have a thought to share with me ,Cause i need to overhaul my engine thought of upgrading performance-my engine have massive oil leak
Please share your thoughts fren
Carburetor Car and FI
