check d "licking" from d top (rocker cover, head, sump etc). go from d top till d bottom. frm my exp, if d oil leaks to ur extractor, usually d top part of ur engine (rocker cover gasket / head gasket / camshaft pulley o-ring worn oredi). dun forget 2 check at ur gearbox 2. usually d flywheel oil seal pecah after some time. make sure 2 check what kind of oil tht is leaking (engine oil ker gb oil ker).
car difficult 2 start eh. hmm, starter / battery / fuel supply / carb or fuel inj dirty. so many possibilities aa bro. if d cranking sounds rough or funny or weak, it might b ur starter motor
