Engine unstable after general overhaul
Lesley Fung
From Facebook
Aug 28, 2010
23
Kota Kinabalu
my prob is the engine unstable after general overhaul since it is ok b4 overhaul
at 1st engine can start but unstable n later on the distributor coil damaged
after replaced the coil, engine can start but still unstable, then timing belt was checked n then found that 1 teeth mistake. after done timing belt, then the engine can start n this time better than before but still unstable
all sensor was inspected and in good condition, no check engine lamp
what is the prob?can anyone who driving honda experienced before?
my car is honda civic ek3 with d15b 3 stage vtec
EvolutionZ
5,000 RPM
5,027
1,448
what unstable u r mentioning about? if engine vibrate then change the engine mounting, if engine jerking then check the plug coil and spark plug, if engine dying off while idling check the throttle body, if accelerating felt like jerking...check the petrol pump...etc etc....
dirty throttle body also would make idling unstable..
g4i8y0t
1,216
330
683
Kedah
Bro, you have to be more specific. What do you mean with engine unstable? Is your engine vibrates a lot or you RPM goes up and down when idling? May I know why you did the overhaul in the first place?
nyantong
192
50
I once performed a top overhaul for a 4G15 which suffered from engine overheat due to a leaking radiator. After removing the head and cleaning all the carbon, replacing the oil seals and regrind the valve seat, I installed the head back. When I started the car, it felt like it had loss of power and was very rough. At that time, I couldn't figure out what was causing it as there weren't any problems with the timing or sensors. So I figured it could be due to a warped cylinder head and I needed to skim and resurface the warpage. Nonetheless, the car was driven for about a week. By the end of the week, the engine was smoother but still felt weak.
I figured it was all down to the warped head and decided to remove the head again and resurface it. After installing the head back, the engine was once again rough! Boy was I wrong. Nothing I did nor replace solved it. After driving again for about a week, the engine became smooth again but still felt weak. So I kinda just settled and figured the rough idling was due to the engine running in and settling down.
Just wanted to share my personal experience although it doesn't really help to solve your problem.
skyline2m
125
Kota Kinabalu
no check engine light
my RPM goes up n down when idling and sometime the engine off suddenly
---------- Post added at 05:43 PM ---------- 6 hour anti-bump limit - Previous post was at 05:41 PM ----------
my engine leaking and the motor oil come out from the gasket between head n block (head gasket)
suspect the block and head was bent and i do go for resurface for head and block and even line horning
---------- Post added at 05:44 PM ---------- 6 hour anti-bump limit - Previous post was at 05:43 PM ----------
Seems like u didnt check the spark plug. Shall try use other good one to test it
not spark plug prob
---------- Post added at 05:45 PM ---------- 6 hour anti-bump limit - Previous post was at 05:44 PM ----------
try to plug in MUT/diagnostics scan to identify the problem...i think yr car needs a retune...
no check engine light and mechanic have check (OBD 1) no need diagnose, just jump 2 wire from ecu but no signal of sensor prob
the mechanic also have diagnose equipment
Lesley Fung
From Facebook
23
Kota Kinabalu
try check the ignition timing, spark plug and plug cable.
checked, even the mechanic have timing light. he said all ignition are ok. not much different from the actual timing.
recently he said the air cond idling valve got prob then i bought a used idling valve but the prob still same
Veloc
3,234
991
Sabah
Generally bad workmanship I guess? As overhaul suppose to be a lot of new parts and engine is practically new. You sifus here can point some problems and hope your mech can solve it without incurring too much extra charge.
Lesley Fung
From Facebook
23
Kota Kinabalu
yupp. hopefully so
at the time i send for overhaul, my block n head do go to engineering for skimming because suspect both are bent
g4i8y0t
1,216
330
683
Kedah
I think u should go back to the mech and complain to him about the problem...
It all started with my odometer getting stucked and not moving. I took apart the meter console and managed to get the odometer fixed DIY. Now my prob is that the speedometer needle no longer moves smoothly. I believe I did not re-install it back properly. I am stumped because the speedometer needle assembly has got a very small ball bearing (just one) and I am not sure where to put this. My needle would move up with increase in speed but once I am slowing down, the needle does not move...
