DIY Intercooler Water Spray
Waja4646
227
Guys need ideas and how to knowledge on Intercooler water spary DIY...
kruger
521
A.Setar
if you want a simple diy, just use 2 windscreen spray nozzle, 3 way aquarium tube connector and aquarium hose. connect it to ur windscreen spray hose and voila!!!
Waja4646
227
Diy
Kruger thats what I'm thinking of....at the moment I already bought the windscreen washer from Abang Shop..........hey u have a proper diagram or anything.....like a photo or what thankx bro
WAJA2003
2,107
22
Shah Alam
use u waja windscreen washer better,then that abang washer put in u bonet...
Find 1 fit fit place to put u waja washer nice nice shoot to u huge intercooler...
then if u like,u bonnet dont use water liao lorr,only intercooler use water lorr,bcs waja washer tangki cannot put 2 motor 1,not macam wira a/b or satria hv 2 motor..
hope u berjaya larr,effect or no donno larr..
ylkien
499
KL/PJ
A better idea.
Make a simple circuit, which acts as a thermometer switch (a lot on the web) and connect it to your 12V battery directly (make sure you have a rectifier). When the temp goes to certain lvl, the water pump will automatically turn on and cool the intercooler down automatically :)
Might be doing that during the holidays.
chinozie
Very Young Member... :D
3,429
170
5,163
Damansara
4age20v.blogsome.com
just curious...
how about...
buy a water reservoir...a simple one...and easy to install in ur engine bay...
connect the wiring to battery and make a switch for it...
the connect the hose to the intercooler or maybe ur radiator...:D can aaaa
howiechoo
8,000 RPM
8,857
Bukit Jalil
where to get the temp sensor?
huakenny
LB Performance
9,126
240
Kota Kinabalu
beter change the water spray to a bigger pump so the water pressure is higher...
conmect it to windscreen sray is works but the pressure very low only...not so effective...
most of my fren customized a water tank at rear boot....to ensure the water is cool everytime....
my 2 cents....
howiechoo
8,000 RPM
8,857
Bukit Jalil
actually the water spray on ur intercooler will make the intercooler stuck with dirt and dust..the wter will catch the dust and dirt when ur car running and then it will dry and the dirt and dust will stick on ur intercooler...just my experience
huakenny
LB Performance
9,126
240
Kota Kinabalu
Even without spray water to IC...dirt n dust oso wil stick to it.....rite?
howiechoo
8,000 RPM
8,857
Bukit Jalil
spraying water to it, u are actually adding the percent of the stuck of dust...
at least withoud the water, those tiny dust will not stick on it...use ur logic..water can trap the dust....
There are quite a number of Mercedes owners running their cars on Tufoil.
Two Mercedes-dedicated service centres have added Tufoil to their list of must-haves.
In Segambut-KL, SPEEDFORM ( Tel: 03 6258 7289 ) even boast of a Dyno made by Bosch. It is probably the only Mercedes workshop in the country to own one and this was installed about 10 years ago.
It speaks volumes for the owner, Freddie. Incidentally, Freddie, a master mechanic first tried Tufoil in his Mercedes 300SE on Aug 6...
