difference between rvr and evo engine
Nally
18
1,503
hi to all bro out there. i'm using perdana with rvr engine. can u all tell me the differences between this 2 engine and how to mods rvr so it can be powerfull like evo.
---------- Post added 04-16-2010 at 12:00 AM ---------- 6 hour anti-bump limit - Previous post was 04-15-2010 at 11:57 PM ----------
bumpp....
mhaziem_ke30
117
bumpp....
wahh so how was it using rvr? manual or auto gb? :driver:
oly
824
2
3,018
Lumut
bumpp....
the diff is the turbo RVR TD04HL and EVO TD05H,injector RVR 450 and EVO 510,ecu evo 1 is 7701,evo 2 is 2468,evo 3 is 2364,rvr is 2467...cam i dunno got diff or not...but other almost the same...u just change turbo n injector...ecu still sufficient to handle that mod...my friend using rvr with evo 3 turbine and 510 injector...almost like evo 3 power...
fuselage
Over 10,000 RPM!
10,169
20
shah alam
get haltech ECU + TD05 turbine + evo3 injectors enuf....
hehe...haltech RM 2k++....tdo5 evo3 RM 1.2k....injector RM 300
total around RM 3.5k
rvr rs 230hp manual price now RM 6.5k....if plus that 3.5k...total 10k..should be more than enough to buy a standard evo 3 halfcut
hehhe.....
budakkampungaje
317
Dengkil
Mitsubishi RVR-Grade Super open gear
Displacement, cc 1997
Engine model 4G63T (turbo intercooler)
Max.power (Net), kw(PS)/rpm 230 ps (169.17 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm 29.5 kg*m (289.30 N*m) / 2500 rpm
Power density 6.65
Engine type Serial 4 cylinder DOHC16 valve IC turbo
Engine information
Fuel system ECI-MULTI (electrically controlled gasoline injection)
Turbocharger Turbo with intercooler
Fuel type Unleaded premium gasoline
LEV system (Low emission vehicle) No
Compression ratio 8.5
Bore, mm 85
Stroke, mm 88
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 10.5
Fuel consumption at 60 km/h, l/100km
Mitsubishi Lancer Evolution III RS
Engine model 4G63T (turbo)
Max.power (Net), kw(PS)/rpm 270 ps (198.59 kw) / 6250 rpm
Max.torque(Net), N*m(kg*m)/rpm 31.5 kg*m (308.91 N*m) / 3000 rpm
Power density 4.41
Engine information
Fuel system ECI multiple (electrically controlled gasoline injection)
Compression ratio 9
Bore, mm 85
Stroke, mm 88
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 9.8
Mitsubishi Lancer GSR evolution III
Power density 4.67
Engine information
Compression ratio 9
Bore, mm 85
Stroke, mm 88
Final gear ratio
mhaziem_ke30
117
hehhe.....
hehe your right bro..but what's the hp for ev03? more than rvr right?:proud:
ruckboyz_85
81
14
1,508
Hufcut for rvr (non rs) auto rm3.2k, manual rm4.4k..for manual u need to buy additional items if installed at wira/satria (compulsory):-
1) Pedal set and clutch pump evo/lancer (if ur car use clutch cable) rm350
2) Radiator evo or gsr or aluminium radiator rm250-rm350
3) Condenser aircond evo/lancer (if ur car use short condenser) rm90
4) Drive shaft evo rm280
Total = rm4.4k + rm350 + rm250 + rm90 + rm280
= rm5370
Compulsory upgrading:-
1) Front and rear absorber rm500 (standard evo)
2) Rear disc brake rm600 (lancer)
3) Front mount intercooler and piping rm800 (evo)
New cost = rm5370 + rm 500 + rm600 + rm800
= rm7270
Additional upgrading to match evo:-
1) Turbine TD05 rm1.1k
2) Wiring complete set evo (ecu, cam sensor, injector, etc) rm1.9k
3) Throttle body evo rm350
4) intake manifold evo rm100
5) subframe, lower arm, steering rack evo rm500
6) Engine mounting evo and crossmember evo rm300
7) Dashboard complete set evo rm1k
New total cost = rm7270 + rm1.1k + rm1.9k + rm350 + rm100 + rm500 + rm300 + rm1k
= rm12520
CONCLUSION: Hufcut EVO 3 RM9800 vs RVR RM12520
RM12520 doesn't include foreman fees and other replacement items such as clutch kit set, timing belt kit, engine oil, gearbox oil, oil seals, etc...
Additional info:-
1) wiring engine rvr mixed with your old wiring
2) dashboard rvr discard
3) lower arm rvr discard
4) front absorber rvr discard
5) aircond system rvr discard
6) Top mount intercooler rvr discard
7) Radiator rvr discard
8) Condenser aircond discard
9) Driveshaft rvr discard
10) Pedal set, clutch pump, gear level rvr discard
11) Meter rvr discard
Those discard items cant fixed into wira/satria chasis..u can sell it to earn money to whom interested..
One more, rvr engine use crank sensor..evo use cam sensor
All calculation above only my estimation to share with all ZTH members..If im wrong, please correct me..:adore::nurse::biggrin:
mhaziem_ke30
117
usually installation fess including oil change / gb oil change / spark plug / timing belt is around how much for rvr?
carlmc
75
1,508
I almost took the rvr cut before..luckily i bail out last minute...got myself an evo..wayy better..huhu..but vr4 of coz better..hehe
fardilla36
131
Just need some information from u all...
Can engine evolll complete use wiring and ECU from RVR. Its support?????
A Post Every 5 Mins
actually this problem come after i take out my battery from my car... the purpose i take out the battery is to clean its terminal using sand paper. after that i installed it back. then i try to start my car,unfortunetly my car cannot start at all...why?? is it because the 2 way alarm that i installed?? i have reset already my 2 way alarm but still cannot start. i try play radio, try use power window, on the headlight all can!! when i try to start my car i juz heard sound's like small...
