The difference between FF hatch & FFcoupe
Night Fury
Jun 11, 2013
6
Thank you for your time to read this treat,
have some questions on types of front wheel drive cars,
What is the difference between a FF Hatch and a FF coupe?
what are the pros n cons of each car on track and daily driving?
mc888
196
59
Little HK
I'd say the center of gravity of the hatch is 'higher' due to the lack of boot. Thus 3-wheeling is very common in h-hatch if driver hard but it won't happen in a coupe.
RENESIS VIII
7,000 RPM
7,063
950
Ipoh
Since most hatch is shorter than coupe, so the wheelbase is shorter too. So, I think that the hatch will have a better handling compared to a longer wheelbase coupe.
mADmAN
1,840
547
3,213
also take note that the hatch doesnt have the extra weight at the rear... so u can throw the car around corners easier.
neohadri
200
34
Hatch can have higher drag coefficient due to bigger air turbulent size at the rear side compared to coupe
1 series coupe looks waaaaaaaaaaaaaaay better than 1 series hatch.
Pretty much applies for almost all cars makes too imho.
g4i8y0t
1,216
330
683
Kedah
For a sports FF car, I don't think the difference in body styles matter in terms of handling. However, suspension setup, weight distribution, power/weight ratio and throttle response do matter.
ixeo
4,788
3,080
KL, Malaysia
Civic EK looked better than EJ imo.
Satria GTi vs Putra? tough call.
1 series hatch was an abomination.. same with most of the X series.. its the BMW for people who couldn't afford the whole car, so they buy just the front (1 series hatch)
cRazYee
307
63
Can expect a hatch to be heavier because it's just like saloon but with a short boot.
Coupe is sport oriented. Mostly 2 doors, hence lighter, mostly.
In term of weight, i think it's another way round
Unless you mean 4 door hatch
---------- Post added at 01:44 PM ---------- 6 hour anti-bump limit - Previous post was at 01:42 PM ----------
Different in style will causing different weight distribution
So sometimes, it matters
Can u describe the ride one will have for these 2 senarios :
1) hard spring + soft absorber
2) soft spring + hard absorber
My car is wira 1.8 original spec. I am planning to use waja rear spring and vr4 front spring to match with standard wira 1.8 absober. My car will be higher than normal cause by the thicker spring ( this is my intention ) but how about my ride ?
Will it be too stiff ?
TQ
