Hufcut for rvr (non rs) auto rm3.2k, manual rm4.4k..for manual u need to buy additional items if installed at wira/satria (compulsory):-
1) Pedal set and clutch pump evo/lancer (if ur car use clutch cable) rm350
2) Radiator evo or gsr or aluminium radiator rm250-rm350
3) Condenser aircond evo/lancer (if ur car use short condenser) rm90
4) Drive shaft evo rm280
Total = rm4.4k + rm350 + rm250 + rm90 + rm280
= rm5370
Compulsory upgrading:-
1) Front and rear absorber rm500 (standard evo)
2) Rear disc brake rm600 (lancer)
3) Front mount intercooler and piping rm800 (evo)
New cost = rm5370 + rm 500 + rm600 + rm800
= rm7270
Additional upgrading to match evo:-
1) Turbine TD05 rm1.1k
2) Wiring complete set evo (ecu, cam sensor, injector, etc) rm1.9k
3) Throttle body evo rm350
4) intake manifold evo rm100
5) subframe, lower arm, steering rack evo rm500
6) Engine mounting evo and crossmember evo rm300
7) Dashboard complete set evo rm1k
New total cost = rm7270 + rm1.1k + rm1.9k + rm350 + rm100 + rm500 + rm300 + rm1k
= rm12520
CONCLUSION: Hufcut EVO 3 RM9800 vs RVR RM12520
RM12520 doesn't include foreman fees and other replacement items such as clutch kit set, timing belt kit, engine oil, gearbox oil, oil seals, etc...
Additional info:-
1) wiring engine rvr mixed with your old wiring
2) dashboard rvr discard
3) lower arm rvr discard
4) front absorber rvr discard
5) aircond system rvr discard
6) Top mount intercooler rvr discard
7) Radiator rvr discard
8) Condenser aircond discard
9) Driveshaft rvr discard
10) Pedal set, clutch pump, gear level rvr discard
11) Meter rvr discard
Those discard items cant fixed into wira/satria chasis..u can sell it to earn money to whom interested..
One more, rvr engine use crank sensor..evo use cam sensor
All calculation above only my estimation to share with all ZTH members..If im wrong, please correct me..
