How to improve my friend >>> Wira Handling !!
smallmaster
177
Johor
Hey sifu. How to improve my buddy proton wira. so far he have done GAB ss series, complete UR bars. It is 1.5 chassis. Now he asking me whether there is aftermarket racing arm for wira:banghead::banghead:. I also dono wat to tell to him. so sifu plsss help..list wat else can improve the handling of car as a race car like arb, arm and etc...
Pls list out..........:wavey:
smallmaster
177
Johor
OK Thx bro 4r d superpro bushes.
Then wat else sifuuu..... ???? like evo3 arm n arb all can ar ?? piiiiiLLLLiiiiiiiiisssss help
joev8796
145
evo 3 arm ah... if reali hav no prob on finance, thn it is a gud thing 2 invest. if da arm doesn't come wit new bush thn u replace it wit superpro 2. bout da suspension, u'l nid a suitable set 4 our malaysian road condition. if 2 hard thn u suffer on wavy road
calvin9683
1,768
171
JB
evo3 front lower arm will move ur tires futher to the front...around 1inch if not mistaken....if u r using big rims/thick tires wif stock wira bodykit, it might sangkut front bumper...
n also, the ARB for evo3 lower arm is connected to ur front absorbers...this u need to check ur fren's current abs whether it has the place to mount the ARB.....
well...if ur fren is so interested in all the bars....
go to ultra racing n get ALL the bars dat they hav for wira lo...
speed2horizon
2,798
334
1,683
Can.. pnp. Provided ur absorbers have a mounting bracket to mount the linkage.
Thay are not expensive anyway. Ard RM400/set. And the bushes are a little stiffer than stock bushes. So, no need to place with super pro untill they are damaged.
Only abt 10-15mm forward. It increases the wheel base and mproves of the caster angle when turning the steering.
Ultra Racing, value for money. And the work...
U can find the rear arb for MIVEC. Or Wira 1.6/1.8, Satria GTI, Putra. Good enough...
basis
24
1,503
Hi Guy
Have you change the spring also , lower spring offer greater stability . the 2nd criteria is type of tyre you are using the width, height all inter related - Try those low profile 50 series with 205 width. Make hell off difference in car handling characteristic . Last part weight ratio-- move battery to the back trunk to shave few KG ( last option most less cost effective)
Happy driving:driver::rofl:
---------- Post added at 11:05 AM ---------- 6 hour anti-bump limit - Previous post was at 11:02 AM ----------
Ooh yeah miss out
UR - Bar is a must --- super bang for the buck, you can feel the difference instantly , without changing your car setup. I got it in my matrix and myvi, Excellent stuff :adore::adore::biggrin:
Dec 25, 2009
2
Dear Sir,
Are you looking for High Power HID Xenon kit? 75W, 100W,……
Are you looking for Adjustable Color Temperture HID xenon kits?
Are you looking for High Reliability HID conversion kit with competitive price?
----Yes, we can do it for you.
CARRUIC INTERNATIONAL GROUP (HK) CO., LTD is a professional manufacturer and exporter of car accessories with offering the OEM and ODM services.
More details about us and products please refer to our website and contact us: CRC-Guangzhou Card Electronics Co., Ltd. --LED HID
Thanks & Best regards!
Mr. Lee
CARRUIC INTERNATION GROUP CO., LTD
503#, Yongfu International LiYuan Breakout, No.45 Yongfu Road, Guangzhou, China. 510000
Tel: +86 20 22020939
Fax: +86 20 62682353
E-mail: [email protected]
Website: CRC-Guangzhou Card Electronics Co., Ltd. --LED HID
LittleWhiteWagon
1,656
187
P.J
Hi Guy
Ooh yeah miss out
205/50 on a 1.5 wira? MAD thick weih, go for 195/50/15, it wont mess up your speedometer and its still grippy :biggrin:
Oh you could try autofoam! It helps quite a fair bit also...
boyzone
2,669
5,148
Btw, what type of handling ur fren want?
High speed stability, conering handling? or just city drive handling?
base on what he has is good enough already.
For local car, what u need is to purchase 1 set good quality coilover hi-low soft hard suspension kit.
test with few set of spring rate set up to suit for what he want.
2nd, 3 points fender bar and 4 points lower arm bar are the must. other is just depand how is ur budget.
3rd, try to get a set of Mitsubishi complete bottom chasis to replace... 22mm front anti roll bar and 16mm rear anti roll bar will assist a lot.
This is what I did on my Satria... if with this type of set up still not enough, think he need to change the car. :biggrin:
hope can help.
zac
1,347
231
Johor Bahru
if still not ok with the above then spot weld car body and install FIA approved 12/16points roll cage... confirm racing car...
speed2horizon
2,798
334
1,683
hope can help.
aiya... No need to change car first. can still go for evo 2/3 lower arm chasis with direct mount 17mm arb. Handles well... Longer wheel base n better caster angle.
Agreed with better coilovers.... But where got so many sets of springs with different springrate to try. Yah.... Titan can do it. Test until u feel good. Change until u feel satisfy n 2 years warranty... I wish I could afford to have. Won't be thinking of until my Tein worn off...
yamen... Autofoam + welded body + full roll cage.... Racing body. HKS/D2/Aragosta/Ohlins absorbers + evo 2/3 front arb + FTO rear arb = racing set up on track = ultimate vibration on the road(applicable at Malaysia road)
zac
1,347
231
Johor Bahru
yaya :) its a good way to judge whether gals are using maximizer or "true" self through their bouncing boobs... lol~~
calvin9683
1,768
171
JB
zac....
if dat's wat u want...
my current cusco adjustables can do it...
gimme a call if u wanna "test"....
i help u fetch the gal...hahaha
zac
1,347
231
Johor Bahru
no need cusco lah, my humble hotbits already makes my 3 layers tummy bouncing so i guess it's work well on boobs test too...:biggrin:
smallmaster
177
Johor
hahahhahahha....can fto rear lower arm n arb fixed to wira ( evo is better than fto or else ??? )
.... this wira is build for corner, high speed stability. Going to transplant evo3 heart. budget is not a problem for this guy!!!
so far, complete UR bars has been installed except the middle lower bar n side lower bar, GAB SS SERIES ( work well ), Lenso Project D rim with 205/40.
Wat else got ah bro? only the Front lower arm evo3 hahhh ??? how bout the front evo3 arb, how to fix hahh,it fix to suspension hahh ?? pilissssss explain ...
how bout the rear arm n arb ( fto or evo ) ?
speed2horizon
2,798
334
1,683
zac....
MEHAI..? Suddenly become porn discussion jor...?
.... this wira is build for corner, high speed stability. Going to transplant evo3 heart. budget is not a problem for this guy!!! ?
U won;t be able to fix the EVO rear ARB unless u convert your body into an AWD body. Meaning to say, cut the floor and replace with EVO floor. Else, the curving on the EVO rear ARB will sangkut on the body..
So, FTO is the thicker ones(21mm if I'm not mistaken) compare to MIVEC(17mm) and GTI(17mm). But harder doesn't means better. It mae also cause over steering of ur car. So far, I heard MIVEC rear ARB is good enough.
so far, complete UR bars has been installed except the middle lower bar n side lower bar, GAB SS SERIES ( work well ), Lenso Project D rim with 205/40. ?
GAB...? Muahaha.. how to high speed corner then..? If Japanese GAB ok la... BTW, Just FYI GAB is made in Malaysia. Same manufacturer as the absorbers brand PXXther... The true Japanese GAB is ony available from halfcut. No more new Japanese GAB.
Better fo for Real Japs absorbers or at least HWL/Hotbits/Titan built up their brand by their own effort. And not use a name of a closed down Japanese brand.
Ultra Racing is bang for money. But it doesn't mean the best. Antiroll Cage will makes u feel damn 97 good. Replaces all the bars...
EVO 2/3 lower arn has to come together with the ARB. Yes, mounted on the absorbers.
Rear FTO ARB, need to get the bracket and the bush when buy the ARB.
If u really need a good high speed handling... The suspension system(absorbers, ARB, Chasis, Steering) can gives u up to a limit....
Changing all the bushes to PU bushes. Reinforce the car frame via autofoam.
Get a modified clutch-pack aka full lock LSD on your GB. U'll immediately feel the difference....
Then, u are talking about good handling.
zac
1,347
231
Johor Bahru
cornering ability and high speed stability is totally different league lah... satria, 2drs civic, citroen saxo, renault clio all these short length car are superb in cornering... longer length definitely have better high speed stability... you can't hv both best things in the world...:biggrin: since your friend car is turbocharged and wira i think target for hi speed is good...
BTW, if money no problem why dun buy another car and mod? any special reason?
smallmaster
177
Johor
Thxxxxx 4 da advice sifu...
dono lah bro for wat he mod Wira. i never ask him also. as long he satisfied with dat car. maybe in future he will get anoher car.
hello everyone, just wanna ask your folks opinion.
I had just convert my SEG AE111 including its dashboard from the Toyota AE111 BZR model. Since the BZR type dashboard is designed for 2 doors, therefore it doesn't really fit for my SEG 4 doors. Now I can drive la and then the dashboard is fitted good enough la. However, i am thinking to modify my dashboard so that it will look nicer la in terms of the fitting and other issues like coating the dashboard and adding a little more of vynil...
