4g93 Mivec Turbo Waja project(Many pictures be warned)
jay_lancer
292
70
28
Thailand
Thanks for the detailed post, it could be a very useful reference for me if I want to evolve my 4G92 Mivec Lancer as it is using similar tech as your Waja.
Love it, just need the time and the $$ LOL
:adore:
Nightstalker1993
267
130
Subang Jaya
:adore:
Glad it could help others around. Another thing I forgot to mention in my post is to use the 4agze pistons with the 4g93 crank you'll have to machine the corners of the piston skirt slightly so that it can clear the counterweight . If you have all the items in hand you will realise it pretty clearly.
y2188
441
42
28
mana ada o, i drive slow slow only :sleep:
burnout cover picture more lanci
fastest jack on the road
Thanks! Still far from complete though, even the brakes are still stocks :rolleyes:
My car entered workshop around end of October 2015, and engine started only around July 2017, during that period I rode motorbike only :beer:
Sien, thought that i can have some fun as anonymous hahha
eh the skirt, how do you machine it? like a tri-angle shape maintaining the skirt's length?
Nightstalker1993
267
130
Subang Jaya
there's a reason why my nick is nightstalker :cool:
I also not sure, I only remember measuring it agak2 need to cut how much then workshop sent to machine shop and cut.
punk
360
76
Negeri Sembilan
ACL Race bearings for the conrod as I couldn't source the MIVEC conrod bearings and the conrod bearings seem to have no difference in design unlike the main bearings.
Hi Sifu,
How to properly select for ACL bearing for conrod? I heard aftermarket dont have any marking number on it.
My Stock proton have number "2" marking for all 4 conrod.
TQ
Nightstalker1993
267
130
Subang Jaya
Hi Sifu,
TQ
Not too sure about selecting conrod bearings in relation to that, but in the 4g9x manual they mentioned about checking the reading on the crank for the factory which is determined by the crankshaft journal dimensions, which means they have 3 different bearings for different factory sizes. But then again if you had polished your crank it may not be as accurate as it should.
These sizes are only applicable if you purchase the original mitsubishi conrod bearings, which I cannot source locally, probably can get from Amayama though.
Rule of thumb is to check the bearing clearances using plastigauge on every bearing and check with the manufacturer's recommended clearance and if all is good then it's ok.
sanekit
Dec 9, 2015
1,616
157
nice build! may i know where you bought the welding cables, the battery and the circuit breaker and roughly how much the price is? :biggrin:
Nightstalker1993
267
130
Subang Jaya
Nightstalker dude : The 150A circuit breaker is essential ke? I think I need to add this
If your battery is behind and you're running a looong line to the front(which is confirmed), then you will definitely need some kind of fuse to protect from short circuit in case the long line gets severed in a crash or wear and tear due to chafing etc and cause a short circuit. Those large cables combined with the low internal resistance of our lead acid battery, will cause it to pull like more than 1000amps(in theory) if it short circuits and will produce god loads amount of heat within the battery itself and the cable probably causing the battery to explode or fireworks show at the cables causing fire in a worst case scenario.
The reason I chose a circuit breaker is because it have a lower resistance than a comparable 150amp fuse and I can easily disconnect the electrical system in case I want to do maintenance relating to the electrical system. Alot easier than removing the reinstalling the terminals.
Thanks! I bought the welding cables here, the '500A' version which as you can see in the specs provided it's 70mm^2 cross-sectional diameter which puts it at an equivalent of a 00 gauge cable which should be 67mm^2. Don't believe those amperage ratings as they are all purely marketing. If the cables are copper, the load carrying capacity is solely dependent on the cross-sectional diameter of the cable and nothing else.
Battery is from a company called 'Gama Alliance' in puchong and the battery is an MSB MS12-65 ULTRA which I see one person selling in Lelong as well, but I remember purchasing from that company slightly cheaper. These are high quality AGM VRLA cells and not your normal car battery, these are meant for deep discharge which was why i opted for the larger size to compensate slightly as deep discharge batteries have a higher internal resistance compared to your usual car batteries which is designed for high current supply for a short period of time. Crimping and terminal lugs is done by a company called 'Conway' in Klang and he charged me a decent price but he told me he don't usually offer crimping services as their core business is selling the terminal lugs and crimping tool.
Circuit breaker was bought on eBay here. Don't get those china circuit breaker which can be bought for like rm20-50 or so as they're pretty crap, already broke one and another one i swapped to this as I was not confident in the China unit.
Hope this helps! Took me very long to source the batteries, cables, terminal lugs/crimping and circuit breaker when I was planning it last time though.
marsha1l_v6
666
130
543
nice build there....and thanks for the sharing..
how long does it take to rebuild since you engine spitted out piston?
Nightstalker1993
267
130
Subang Jaya
Thanks!
Engine spat out it's piston on late October 2015 if I remembered correctly. First startup was July 2017, so almost 2 years. Engine actually went into the car in late 2016 so it was sitting there after I assembled it for almost a year before starting which is why it rusted so bad. In between that I rode motorbike. Anybody interested in a Suzuki VS125? :rolleyes:
I use ANL fuse during relocate battery to rear. Circuit breaker more user friendly.
Cable shorts, BBQ the car. :rofl:
Yeah that's the more common option. But circuit breaker have lesser resistance than an ANL fuse of comparable amperage rating so that's another reason as well. My car starts as if the battery is in front, very strong start everytime :biggrin:
15,390
Where'd you buy the breaker from? I think I need to get one.
sweelt
Nov 6, 2016
2,306
248
Thanks!
i can see you use black color pure copper cable. Yup engine start easily.
Orange color welding cable not that cunn in long run, just copper plating. No harm to invest more.
there will be a dealer to handle our TiTAN business soon :)
they accept credit cards, but pls bear with them and help with the (maybe) extra % for the credit card service..
these guys are reputable in the car modding industry and were selected carefully for their professionalism and level of expertise.
i will announce later when the deals have been finalised and very sure who'll be our dealer :)
