Do Ultra Racing Bars increase Car Safety?
sweelt
Nov 6, 2016
2,306
248
after digging , this thread got my interest because of sausage fest. :biggrin:
So the room bar got convincing story. Will in my list.
How about lower bar ? so many from front, side, middle, rear. Which one is good for starter, for wira.
UR bars are expensive now.....
I would suggest the usual suspect;
1.Front upper bar
2.Front lower bar
3.Rear anti roll bar-if yours dont have storck arb.( Most expensive )
4.room bar...since its already on your wish list..
Depending on suspension setup and tires, installing the rear upper strut bar can cause oversteer as the rear becomes too solid.
sweelt
Nov 6, 2016
2,306
248
Thank for good suggestion.
I have those important bar installed. Fender bar is the expensive one. Can feel instantly the different.
Wanna know what bar is crucial for lower body only.
as my experience in wira/satria body....
crucial bars
1- 4point front strut bar
2- fender bar
3- room bar (but need to modified...add 2 more brackets in the middle to bolt the bar at chassis tunnel can hook up to front seat bolt location to make it simple)
4- biggest front and rear ARB available from UR
5- 3point rear strut bar
all other bar at the bottom might not doing much...plus the hassle of scraping it everytime at speed bump
crucial bars
2- fender bar
sweelt
Nov 6, 2016
2,306
248
crucial bars
2- fender bar
thanks pomen, all in the list. #1,2,4,5
as for front ARB still stock gsr one.
i think left room bar for my setup. :driver:
lsm1991
1,469
185
fender bars, need to weld isnt it?
Hmm... am I the only one who felt nothing with the fender bars? But to be fair I already pretty much every other bar installed. You're missing the side under carriage bars. :biggrin: I had those and had some interesting effects.
hahaha.....sausage fest first
What the hell dude. You need to make it clear what you mean cuz as far as I know a sausage fest is very homosexual. Very. If you are gay then fine - that makes a lotta sense. But if you're not - please clarify! :hmmmm:
Nope. But they'll need to drill holes into the chassis to attach the front part of the fender bar and lock it down with bolts and nuts.
Screw n bolts. I think, I going to weld dead it.
Don't. If done incorrectly there's no turning back. If say your chassis is slightly off, welding means permanently off. And it's attached to your door bolts too. Screw up that weld and your doors will have problems.
If you're gonna weld, sell off your bars, strip the interior and do a full spot weld. It'll work better than bars and if you have the budget install a full roll cage. No amount of bars will be stiffer than this setup. :biggrin:
Well, I just found something that I believe that many have always had this idea especially us who are always stucked in a traffic jam during peak hours and hoping that our car could just fly over all those cars whenever there are heavy traffics
While imaginations/dreams are those things that make something come into reality..after so many years since my childhood, well it could be back to 30 or 50 years ago that someone had that kind of imagination and wish cars could fly...just that it is...
