Ultra Racing Product??
lancemapei
lancemapei
105
11
Dear All ZTH Bro,
i thinking to add-in full set of ultra racing chassis enhancement bar to my lovely car, but when i group up everything before install total weight up to 30kg, i have feeling........ spending so much for reducing weight then suddenly add up 30kg.... :bawling::banghead:
therefore all bros, any solution???
thanks for all comment.:adore:
^pomen_GTR^
7,000 RPM
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
don't use all bar...
just install what u really need to improve your chasis only... :adore:
beatnik
beatnik
924
74
3,028
30kg.. that's A LOT.. lol
does your car handles a lot better even after the adding the extra weight? or it just 'feel' better.. your car might go round the corners faster without the bars (less weight).
like ^pomen_GTR^ said, just add where it matters most.. dont la get succumbed by the advertisement and buy all bars.
D7zul
D7zul
2,697
848
Shah Alam
i think the most important thing is strut bar & antiroll bar.. both front & rear..
try that 1st.. if still not satisfy, can consider other bar..
:wink:
---------- Post added at 11:39 AM ---------- 6 hour anti-bump limit - Previous post was at 11:37 AM ----------
oh ya.. what car u wanna install those bars?
jy_1990
jy_1990
25
add antiroll bar 1st, then tune the rear and front stiffness of the car depending on understeer and oversteer chracteristics
if it understeers too much, stiffen the rear, if it oversteers too much, stiffen the front
lancemapei
lancemapei
105
11
:wink:
i driving perda-evo,
compere with original eterna strut bar make from aluminium which is much lighter then UR strut bar T.T
^pomen_GTR^
7,000 RPM
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
original eterna i think lighter...
BUT
UR better in term of rein-forcement because of more mounting point..more rigid.... :adore:
D7zul
D7zul
2,697
848
Shah Alam
BUT
and UR also use thicker bar..
about the weight.. u only need to worry if u r going straight..
for corners.. those bars will help ur lap time :wink:
^pomen_GTR^
7,000 RPM
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
S2H..got great deal with go-kart provider? :biggrin:
speed2horizon
speed2horizon
2,798
334
1,683
Nope... In Go Kart, the chassis is the suspension. Our car too, chassis is part of the suspension. Unless ur car is going full track where roads are acceptably flat.
BTW, 30Kgs is equivalent to a 10 point roll cage. might as well go for roll cage.
^pomen_GTR^
7,000 RPM
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
i'm not arguing your theory/opinion.....but i got a different view for a car chassis...this is what was i'm thinking...maybe i'm wrong....but at least this is what i think for now...huhuhuhu
the gokart we all know already that it doesn't have any suspension...so the chassis had to be designed in order to allow some degree of flexing in order to maintain tyre contact with the tarmac surface especially on uneven surface....and also since kart doesn't have differential (straight lock axle) the chassis flexing allow the inner side of rear tyre to lift a bit from tarmac surface and induce better turning radius....
as per car chassis, opposed to that,too much chassis flexing would makes the car wobble on rough surface, therefore resulting in poor steering feel and a major headache to tune the suspension.....with stiff chassis,all the bumps/rough surface change can be made only on the suspension setup and the setup change would work more consistently and predictable between changes...thus drivers can get direct feedback on any change/setup he needs easily without wasting valuable time (especially on race day) to test various suspension setup changes......another good example was the F1 car...because of the carbon fiber chassis tub was so stiff,they only need suspension travel of a total less than 5cm (50mm) to get a good mechanical grip...
and this explain why when normal road cars using stiff spring it goes too bumpy on undulated surface...think as the road rough surface was a length of consistent wave graph....and the suspension travel along it with inverted graph..when taking the spring rate and damping rate of the suspension doesn't match the road surface graph, the car simply bouncing over the graph length....it became worse when the car chassis was flexed during the run makes the suspension graph even more inconsistent with the road graph....in this case a pair of fender bar would make a different where it helps hold the chassis stay rigid and not causing any further distraction to the suspension graph versus road surface graph...and this is also what i think where most ppl say their car becomes better in term of comfort after installing chassis reinforcement bar....the suspension do all their busy job without the chassis flexing causing the suspension behave differently from what they intend to do....
p/s: sorry for the long post....feel free to correct me if there's mistake in my post....me also still learning :adore:
speed2horizon
speed2horizon
2,798
334
1,683
I didn't say leave it flex... What I meant was to allow a certain flexibility instead of completely rigid... And UR bars being installed at each an every part independently will also not hold the car together... It's still not a rollcage.
I have experience cracking my firewall with the 4 points front struct bar... I went back to flexible cusco front struct to allow some movement within...
Just my opinion... Ignore me if u guys disagree.... Chiowww.....
D7zul
D7zul
2,697
848
Shah Alam
crack ur firewall? what car u using?
i have a lil crack on my chassis above my tyre.. passenger side
and i'm using original levin strut & antiroll bar..
speed2horizon
speed2horizon
2,798
334
1,683
Satria lor... The 4 point was mounted on strict tower and firewall.
^pomen_GTR^
7,000 RPM
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
about proton crack firewall u know la the firewall very2 thin...even if using racing clutch (hard to press clutch paddle) also results on cracking the firewall :biggrin:
another famous area for cracking was at the fender chassis (between the strut housing and firewall)..this problem i use UR fender bar to reduce further damage.. :adore:
*in this picture u can see clearly on crack at exactly above the UR fender bar
*another spot of normal crack for this kind of car was near the bonnet rubber lining (top left in picture)
this shows that area have been flexing from the day it rolls out of factory..metal fatigue (worse if use adjustable suspension with harder spring rate) :adore:
beatnik
beatnik
924
74
3,028
This.
also note that adding all possible bars at every corner of the car is not a substitute to a roll cage.
roll cage's primary purpose is to protect the occupant during roll-over (turn turtle). chassis strengthening is just an additional benefit.
speed2horizon
speed2horizon
2,798
334
1,683
This.
Yeah... that's what I was trying to say... No substitution for rollcage...
lancemapei
lancemapei
105
11
thanks all bros comments,
any others way to get perdana chassis enhancement product like Cusco?
or custom make aluminium lower bar?
nasr
nasr
70
3,008
Just install fender bar to my ae101 and the result as what pomen GTR said -
more stable handling especially at bouncy corner road..a good investment..
^pomen_GTR^
7,000 RPM
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
there's also another chassis improvement method yet to try..
autofoaming....
well maybe later in the end year would do the track package for side sill foaming.... :smokin:
speed2horizon
speed2horizon
2,798
334
1,683
autofoaming....
Pro and cons.
Pro, Noise Sound and Vibration reduction.
Felt the Car as 1 piece.
Cons.
If any slight accident th causes dents on any of the ABC pillar, Rocker Panel. Then, the makatlou will be coursing ur next generation... Lolx...
D7zul
D7zul
2,697
848
Shah Alam
Cons.
if there's no foaming also got problem, right? :biggrin:
speed2horizon
speed2horizon
2,798
334
1,683
Hahaha.... The problem is not about the rigidity... The problem comes when u repair. If u filled up all the sections, how the tool gonna reach the outer panel leh.... I'm not siding anyone/brand/product. In fact, I'm complimenting it for the SNV insulation and rigidity...
This is purely based on my friends n my own experience with the foam. One of my friend is also makatlou(ketuk body). He was cursing the owner when the car was sent for repair... Hahaha....
^pomen_GTR^
7,000 RPM
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
surely it is... :biggrin:
^pomen_GTR^
7,000 RPM
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
Haha... looks like some experience there...?
Hehe:smokin:
not my car boss.... :biggrin: but still tempting to try it...just will not do all package la....just some key area maybe...
even if we think about it if the foam already filling all the hollow panel on the side of the car surely bodyshop foreman scratch head how to ketuk back when the panel dented.... :hmmmm:
no wonder your makatlou fren tiau the other guy kao kao.... :banghead:
Pomen : If you go autofoam let me know. I've been wanting to do for a while, but never had the time or money. DIY for this is highly tempting but after surveying the prices of some of the better products out there, it's almost the same in price.
^pomen_GTR^
7,000 RPM
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
actually i've been eyeing for long to DIY the foaming mods....but after looking highs and lows about so many range of "possible" foam and the long process to get it right 1st time, i decided to let the master to do it...autofoam to be exact....will be doing full side(door) sill foaming with high density race formula foam(i think it would be the hardest and heaviest of foam)...recieved quotation from desmond for my car....slightly higher than i tought it would be...hence explain the long wait.... :smokin:
