[DIY] How to decrease engine bay temperature
3309
52
5
508
Nilai
I agree not perfect CAI but atleast there are still a lot of outside air coming thru the hose.
3309
52
5
508
Nilai
ha ha ha...yes agree with you...
Anyway whose car is that...I want to rolling on the floor right now...ha ha ha...
But I saw before someone install at his Odyssey a scoop with double hole....so daring...
twistedichc
Jan 22, 2013
2,930
255
683
Ampang Point
hello guys need to know can this spray can also applied to engine block ?
where can i get ?
i want to spray my engine block to flat black any suggestion how to make it ?
I'm already take out all the internal part so need advise what spray can applied for block engine need flat black colour
:hmmmm:
yepp sure can use 1, manifold is hotter than block maaa
ken yeang
6,617
1,327
where can i get ?
:hmmmm:
make sure the engine block is free from oil stain, grease or dirt. If not the paint wont stick properly and your spray paint will be a wasted effort.
Try engine degreaser. They are tough on heavy oil, grease, etc.
Most engine degreaser are petroleum base therefore you may need to use soap to wash the degreaser off also and then let dry kao kao first
Saring
121
24
Tq will buy engine degreaser this weekend, and wait for block coming back from machine shop after that i will start to build it back :burnout::burnout:
Sent to machine shop, come back should be quite clean, right? If not in the car you can clean with whatever solvents, rather than spray degreaser. Just make sure no dirt and oil before spraying
twistedichc
Jan 22, 2013
2,930
255
683
Ampang Point
or u can go to hardware shop & try to find water based degreaser, ace should have lot for oil & grease, its spray leave rinse method.
guys ...need some confirmation from you all...driving 1.3 efi satria
intend to rev my car from :
1.1st gear 50kmh
2.2nd gear 80kmh
3.3rd gear 120 kmh
4.4th gear 125 - 130 kmh
5.5th gear ..still maintain 125 - 130 kmh
sometimes when i slowly drive from 1st gear to 2nd gear also will face some slipping problem ...
but not always ...
so from the statement above ...the 5th gear am i facing a a clutch slip probleM ? thats why my top speed cannot go any further ?
