help!! my 20v idling problem!!
chinozie
Very Young Member... :D
3,429
170
5,163
Damansara
4age20v.blogsome.com
Alex - try to adjust your VSV for A/C Idle-up using an allen key...look like in the picture given below...normally located near the firewall next to the wiper motor...
alex_khoo
163
oledi adjust tat thing( i got a spare 1...both oso adjust oledi but still same):bawling:
kelvinyong83kh
Nov 20, 2010
39
508
alex : my car got the idling problem when i install the half cut engine that time !!! but now no more problem !!!! i just changed what need to change :
plug
plug cable
fuel pressure regulator
filter
adjusted timing
clean injector
until i pok kai ...... then when i changed 2nd time engine oil suddenly got no problem d ..... :hmmmm2:
but now ... my car got chock during the constant drive !!! dont know y ??? that y iam looking for a pro shop to settle the problem !!!
thank a lot your guide way !!!!
levin818
1,260
321
3,183
Shah Alam
Idling shouldn't drop to 500rpm eventhough with electrical load. Something wrong la... Come la to Kota Kemuning and buy me Old Town white coffee then i'll help you see look :biggrin:
Cronixz
34
Guys,
as i mention earlier after replacing the idling vacuum it was fine for 2-3days...
i've continue monitoring it.. but came back to its existing problemo....
its still revving up to 1200rpm or more... but the funny part is it goes up
either when i hit the clutch to change the gear or else when i switch on the aircond...
sometimes it stays at 1000rpm... but most of the time its more.... relly funny... However, i got an advice from my fren...
he mentioned it could be due to VVT pulley as well. yea my engine has that
"diesel" noise yet does it effect the timing as well?? anyone could advice me on this please?
alex_khoo
163
cronixz...my situaition is TERBALIK with u!!my rpm goes down to 500rpm:burnout:
my car oso got noisy DIESEL sound...maybe it was TRADEMARK for 20v。。lol
Cronixz
34
alex:
yea the diesel sound is common thingy in 4age as i herd in many forums and frenz.. haisss...this issue is js not resolving.... hav to change mounting as well... aredy loosing lotsa $$$.... lookin into priority 1st...
D7zul
2,697
848
Shah Alam
i tot its called FICD
:biggrin:
ahaw
141
6
living with same problem for few years already. normal idling : 400rpm with a/c 800rpm
sometimes engine choking below 2k rpm in 2nd gear..
alex_khoo
163
ahaw; ya..my problem is same v u now!! how u solve it?:biggrin:
kelvinyong83kh
Nov 20, 2010
39
508
all sifu ? mind to ask question ?
1)currently my car's expension tank must top up a bit water every single week.. the
expension tank level when cool time will at min-line then top up to max -line level for a
week!... izit normal for the 4age engine ? seem like the 4age hotter compare to other car
!? or my car got some problem d ?
2)after 2000 mileage engine oil will reduce abit when ramp n drive fast ! but if normal
condition driving for 5000mileage, engine oil not reduce !?... what is this issue ?!
engine oil = wyne 10 40W + blue chem oil system care
any sifu can share some knowledge !?
AE101-Wong
4,448
113
try to check ur steering rack vacuum hose, if tertanggal or poor hose condition will cause the problem u mentioned..
if everything tried, it's time to change blacktop wiring running MAP...hehehehe!!!
Cronixz
34
I realize my steering rack oil seal is kind of leaking .. but very small leakage... could it be due do that???
Hi Guys,
(I am not sure if this is the most appropriate thread for this so moderators feel free to redirect if you see fit)
So, i think its time for me to come home and I want to bring my 2004 Toyota Celica back with me from the UK.
Been reading as much material as I can find and as far as I know, I meet all the criteria to be able to bring my car back and more importantly be able to get an AP. Now the tricky thing is the tax, does anyone know how much tax I would have to pay ...
