y does engine bearing worn out?
phantomRX8
Insignificant Fool
331
5,018
ISS
gti[GSR] said:
wellz dere mite b a reason frequency of it kept repeating...? mahf wen'sc ar he changed block like 3 times n dis tiem comin 2 fourth...
y? wellz from wat i read so far, its da insufficient fuelling....
wah..comin' to 4th engine block?? wat happened there? must b sumtin' wrong wit
injector/ecu/regulator/filter or anything to do wit fueling itself if insufficient fueling is
concerned..gud luck to him
jinkl
4,624
376
3,183
phantomrx8 : hehehhe
gti[gsr] : i also had 2 engines died cos of bearing worn out , one totally blew pecah habis , one gave way to the crank making grinding noise
my problem both were OIL PUMP failure , if u r on 6 bolts 63t then its already common to have crankwall problems, best u go get ur oil pump UPRATED
phantomRX8
Insignificant Fool
331
5,018
ISS
so jinkl bro...u like to take ur crankshaft for a walk is it?? hehe..crank walking is a common
problem for 63T laa...c da effects of crank harmonics?? vibrate all the way to the oil
pump..bro gti how about changing to evo 3 oil pump ?? maybe its rated capacity higher than
vr4 one...just a hunch anyway...
can i actually know wat is the use of installing fibre hood???
is it can absorb heat?? or juz a decoration???
fibre is it very crispy??
thx for answering:adore: :adore:
