guys, anyone know how to clean cylinder head? to remove all the dark colour that stick to the cylinder head...i know it can remove with an acid but i dunno wat acid...mind to share........
Hi I went to car modification and cant find the thread (look thru till page 69)...cause this is interesting and would look more on any diy methods to clean cylinder head...like steam clean or wut?? or just pour in n shake the whole thing......hehehehe...
not decarb la bro...wat i mean is when do overhaul or top overhaul...after take out the head dismantle everything...just the head cylinder...how to clean all the dirt/dark inside cause of the engine oil...
start you car engine,
rev the engine how high is up to you...
then spary some mist of water at the carb intake...
do this for few times...your cyclinder head will be clean off carbon...
burnner u dont get it... i mean only cylinder head not combustion chamber...here`s example of the cylinder head pic...how make it clean from all the dark colour...
it's call gum deposit.usually from a cooked cylinder oil(this is what happen if
u guy's don't change the engine oil regularly as recomended by the manufacturer).
usually we scrape it off.i wonder whether the acid from paint remover can clear
it off?
As I travel outstation a lot, so I'm usually out on the highways and stone chips are pretty unavoidable when we travel on highways especially at the speed we are going.
My few months old car has already obtained quite a number of stone chips on the engine hood and some on the bumper (car is black so pretty obvious white stone chip marks can be seen during day time). I was wondering if there's any product or method that can "magically" repair the paint or is...
