WTA: diy cylinder head cleaning process
shazmi3
1,017
4
Damansara
guys, anyone know how to clean cylinder head? to remove all the dark colour that stick to the cylinder head...i know it can remove with an acid but i dunno wat acid...mind to share........
Lean
UnderCoverProject Founder
221
12
undercoverproject.blogspot.com
hey shazmi3 , i think the topic u r asking now is in one of the tread in zth..i think its under car modification .=)
shazmi3
1,017
4
Damansara
ok thanks!!! but i couldnt find it..anyone know wats the chemical?
grstarbuck
Hi I went to car modification and cant find the thread (look thru till page 69)...cause this is interesting and would look more on any diy methods to clean cylinder head...like steam clean or wut?? or just pour in n shake the whole thing......hehehehe...
huakenny
LB Performance
9,126
240
Kota Kinabalu
decarbonizing lo if u mean to clean the combustion chamber...
the easier n simple way is to get it from zth seller directly if u not sure wat ingredient/chemical to use.
direct buy the ready made decarbonizer...they do offer FOC doing it for u
cheers
shazmi3
1,017
4
Damansara
not decarb la bro...wat i mean is when do overhaul or top overhaul...after take out the head dismantle everything...just the head cylinder...how to clean all the dirt/dark inside cause of the engine oil...
cheers!!
p/s: did i mention combustion chamber?
shazmi3
1,017
4
Damansara
combustion chamber is the space betwen piston n cylinder head....
how to clean...u mean the areas where camchasft located?
btw, u overhaul urself?
yeap i mean where the camshaft located...yeap overhaul myself...
burnner
1,563
4
start you car engine,
rev the engine how high is up to you...
then spary some mist of water at the carb intake...
do this for few times...your cyclinder head will be clean off carbon...
shazmi3
1,017
4
Damansara
burnner u dont get it... i mean only cylinder head not combustion chamber...here`s example of the cylinder head pic...how make it clean from all the dark colour...
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
it's call gum deposit.usually from a cooked cylinder oil(this is what happen if
u guy's don't change the engine oil regularly as recomended by the manufacturer).
usually we scrape it off.i wonder whether the acid from paint remover can clear
it off?
anyone who know how to build 2liter vtec please help me..the tips,what to buy n how to built it without any problems...TQ
