What brand of fuel you guys running?
rayncc
26
1,503
Dear All,
I used Ron95 for my Tezza. Can't afford Ron97. Although compression is high, has no problems or I'll effects running Ron95.
Just sharing of info, what brand of fuel you guys run on?
I swear by Primax 95. Thinks it gives the best performance. Tried 2 tankful of the recently improved BHP (claimed to be Spore Euro 4 grade) but found that it gave poorer mileage not to mention no improvement in performance, from my experience at least.
nappx
2,532
185
5,163
kLaNG-kEy_tEE
Earlier Esso when change to PETRON...stop using it unless no petrol pump..when warning light...
Now BHP or CALTEX
nyantong
192
50
Esso! Every 1000 points gives me back free petrol. Sadly, the amount has dropped by a lot lately
khoo198
1,948
2,067
N9
Mobil Synergy F1+ STP or Prestone octane booster sometimes....:slug:
Supra_Fanatics
Beyond 20,000 RPM!
20,685
3,998
Using Shell Fuel Save 95, never failed me in terms of Good FC, in other words great mileage, performance wise, no complain...
6UE5t
6,756
1,300
Used to fill up with just about everything: Shell, Petronas, Caltex, & Esso. But now only Esso/Petron 95 cuz got loyalty card.
Any other petrol that gives such loyalty card membership?
Supra_Fanatics
Beyond 20,000 RPM!
20,685
3,998
I chose Shell cuz got bonuslink points :biggrin: also proven on Kelisa,
is better FC than Petronas Ron95.
Bonuslink need a lot of points to change for something, right?
---------- Post added at 09:50 AM ---------- 6 hour anti-bump limit - Previous post was at 09:47 AM ----------
Bro., I also using because got stations near my house and office, and of course the smiles card. 3000 points for RM45 fuel, where to get, or can shop in the Petrol Station Mart at 100 points for RM1. Can buy bread, drinks etc., and use smiles card like debit card......:driver:
Supra_Fanatics
Beyond 20,000 RPM!
20,685
3,998
Can say so, but I didn't really check how much points I have as well, but the things to change are quite attractive. Though, things that you change definitely cost less than the amount of money you spend on fuel and also does not cost that much. Maybe few hundred ringgit things, the points
you have may cause up to few thousands ringgit spend on fuel.
I just take it as a bonus item to get since, I pump Shell Fuel, might as well just collect
points as I pump. :smile:
But now gonna test on Petron Fuel...
First try the fuel and see whether suits your ride or not. If not, also no point. If yes, then like you say is bonus, can change for items.....:driver:
Supra_Fanatics
Beyond 20,000 RPM!
20,685
3,998
That is usually the first choice, station closest to house or office......:biggrin:
Ya, trying out different Fuel and see which suits Kelisa best.
So far Shell FC is good.
Mine closest is Esso just 1 min from my house, but I chose to drive down at least 3-5mins further down to pump shell :rofl:
Must have pretty counter clerk or something......:biggrin:
Supra_Fanatics
Beyond 20,000 RPM!
20,685
3,998
Nah, my car told me the fuel there taste better. Makes his stamina better...xD
6UE5t
6,756
1,300
Yeap exactly. Between my house & office also got 3 Petron stations, so it's convenient.
---------- Post added at 08:29 PM ---------- 6 hour anti-bump limit - Previous post was at 08:26 PM ----------
I often pump Shell before when going to my previous project location. I honestly cannot tell the difference between Shell, Esso/Petron, or any other ones.:biggrin:
Dear All,
As mentioned above, i want to know the whether too much negative offset in OEM wheels can cause tire vibrations. Current car is an E46 318ci with stock undercarriage. Wheel hub is still using stock and standard which sits quite inside the fender. Current wheels are OEM 17" with ET37 offset. My mechanic already gave me a preamp that i will experience slight vibration and on-wheel balancing can only reduce it but not cure it completely. As he said, i did feel slight vibrations...
