Guys n Gals...just want to share my experience
Car Modification/Engine Transplant
It's a tricky business, but if you go by the book it'll turned out just fine.
When you want to do engine transplant, pls consider it as a big project as it'll involved a lot of your money. Thus plan it well. Don't intend to do ridiculous engine transplant i.e 1.3 chassis to put 2.0 engine in it, surely the JPJ/PUSPAKOM will failed you...be reasonable how can 1.3 chassis to carry a power load generated from 2.0 engine?
After the engine transplant, I still have that 1.6 road tax for about 6 months...so I have an ample time get a pre-approval(KAWAL SELIA) from JPJ/Technical Division, Putrajaya...got the letter went to PUSPAKOM Wangsa Maju...Entered around 8.00am, drove out successfully 1 hour later ...
B4 go there; check the following
1. No modification/fabrication on engine base mounting and all systems are up and running (Electricals, Braking, all the lights )
2. If engine power increase, be sure to upgrade the brakes as well
3. Clean exterior/interior most important the engine/chassis number must be clearly visible
4. No excessive oil leaks.
I even went in with my
1. 17 inch rim,
2. tinted window(they know which one is illegal)
3. 2.5 inch exhaust pipe, GReddy Muffler (replace the tail pipe to smaller one, originally 5 inch! surely fail)
ALL FOR ONLY RM40.00
went to JPJ and get it endorsed.
as for myself, transplant from 1.6 SOHC carby engine to 1.8 DOHC Turbo engine..
Happy Converting
