Suspension setup for myvi
Aug 26, 2012
503
Sabah
My absorber is almost done ady. Im now looking for a suspension setup that is handle and ride better than the standard setup. I prefer stock ride height or lower a bit also can. My budget is around 1k. Any suggestion?
Currently, Im thinking of the APM absorber + Tein S Tech spring. Is that ok or any other setup better than that around 1k? or only change the absorber?
ixeo
4,788
3,080
KL, Malaysia
stock springs + SACHS touring absorbers.
any lowering springs will be too low on the Myvi.
nickkho91
503
Sabah
Seems like a nice setup. I search over the internet sees good comment on the absorber n its cheap too. Thanks =)
Yup. I prefer stock ride also. Lower also can but not too low. Mine stock SE pass the bump already will kena the bottom when carry like 5 ppl in the car.
quiksilve
64
6
I've been running on SACHS touring absorbers + Eibach springs for 2 years, best set up i feel so far for daily drive
ixeo
4,788
3,080
KL, Malaysia
anyone tried using adjustable KYB before? is it good?
It is horrible on Malaysia roads. Like I said, best setup is stock springs with SACHS absorbers.
quiksilve
64
6
Eibach springs (RM900) + Sachs (F)+(R) (RM350) = RM1250, running on SE2 Rims
jun_ng_1208
476
32
Cheras
Anything but G|A|B because the springs are quite harsh on Malaysian roads, am a user of G|A|B SS fully adjustable, feels great when you drive on track or touge but normal drive will be a back braking experience LOL~
satishchandramohan
369
518
For adjustable , please consider on your setup tuning before complaining on the brand .
Most compact brands patent on most absorber these days . They followed very similar design everywhere .
Its just that the type oil were use for damping .
and spring rate :P
adjustable suspension...just use 1 step lower spring rate than the "out of box setting" can ask to change for free before installation on certain shop...
OKLY
121
6
518
Selangor
Currently I'm pairing GAB sport springs with IMP Comfort absorbers, not too bad and not the harshest setup. I believe if you pair progressive springs with IMP Comfort absorbers you should attain quite good comfort and performance.
Hi guys i just purchase a coilover with a 8kg front and 5kg rear spring rate.
Have not test corner yet but i would like to know what is Wira stock spring rate?
And anyone know what damper setting is best?
Thank you!
