Suspension setup for myvi
Aug 26, 2012
503
Sabah
My absorber is almost done ady. Im now looking for a suspension setup that is handle and ride better than the standard setup. I prefer stock ride height or lower a bit also can. My budget is around 1k. Any suggestion?
Currently, Im thinking of the APM absorber + Tein S Tech spring. Is that ok or any other setup better than that around 1k? or only change the absorber?
ixeo
4,788
3,080
KL, Malaysia
stock springs + SACHS touring absorbers.
any lowering springs will be too low on the Myvi.
nickkho91
503
Sabah
Seems like a nice setup. I search over the internet sees good comment on the absorber n its cheap too. Thanks =)
Yup. I prefer stock ride also. Lower also can but not too low. Mine stock SE pass the bump already will kena the bottom when carry like 5 ppl in the car.
quiksilve
64
6
I've been running on SACHS touring absorbers + Eibach springs for 2 years, best set up i feel so far for daily drive
ixeo
4,788
3,080
KL, Malaysia
anyone tried using adjustable KYB before? is it good?
It is horrible on Malaysia roads. Like I said, best setup is stock springs with SACHS absorbers.
quiksilve
64
6
Eibach springs (RM900) + Sachs (F)+(R) (RM350) = RM1250, running on SE2 Rims
jun_ng_1208
476
32
Cheras
Anything but G|A|B because the springs are quite harsh on Malaysian roads, am a user of G|A|B SS fully adjustable, feels great when you drive on track or touge but normal drive will be a back braking experience LOL~
satishchandramohan
369
518
For adjustable , please consider on your setup tuning before complaining on the brand .
Most compact brands patent on most absorber these days . They followed very similar design everywhere .
Its just that the type oil were use for damping .
and spring rate :P
adjustable suspension...just use 1 step lower spring rate than the "out of box setting" can ask to change for free before installation on certain shop...
OKLY
121
6
518
Selangor
Currently I'm pairing GAB sport springs with IMP Comfort absorbers, not too bad and not the harshest setup. I believe if you pair progressive springs with IMP Comfort absorbers you should attain quite good comfort and performance.
Hot Temps, Low Air Pressure May Lead to Tire Trouble
Proper Tire Pressure Promotes Safety, Saves Gas, Helps Tires Last
WASHINGTON -- Summer time heat and under inflated tires may spell trouble on the road. The National Highway Traffic Safety Administration estimates that 660 fatalities and 33,000 injuries occur each year due to under inflated tires.
The Rubber Manufacturers Association, which represents tire manufacturers, recommends...
