It's a possibility your brake hoses are expanding. Easiest way to tell is to jack up on side, remove the rim, have someone start the car (neutral) then press the brake continuously while you observe the hose. Any sort of expansion is bad. If you do see any - steel braided hoses will help you.Hi Izso,
appreciate the insight.
the reason for me to opt for the steel braided hoses is because my brakes are biting very well only during the first few minutes when I move my car after a cold start and then after upon heating up, the brakes aren't biting much or well
Otherwise it sounds like you have a brake pad issue.
