Stainless Steel Extrator
gtiwtks
157
Wanna know whether the material of steel use to make the extrator will
make any differents?
What is the advantage of using stainless steel compare to normal steel
for exaust and chrome steel? How about the disadvantage as well?
Some one recon me to install a stainless steel extractor base on mivec
design. Worth changing it? How to make sure it is really make of
stainless steel?
koolspyda
2,889
55
5,148
KayEl
koolspyda.blogspot.com
i think if the design is exactly the same (primaries & all), the advantage may only be lighter (in weight) than stock.
other than stock manifolds being a little restrictive (as likely be cast? or crude in the joints) & thus hampers a little on flow.
m@ttz
1,846
13
klang
stainless steel of coz nice, shining shining, light n no worry for rust, heard people said sounds also will a bit diff, donno la..
GT_AUTO
3,503
71
1,648
K.Trg
www.facebook.com
lighter then stock lor,flow better lor(if mandrel bend),last longer lor,look nicer lor
hmmm......what else ar???
tofu_manic
1,342
91
5,148
can check whether hair messy or not when tweaking engine :P
on a more serious not, if u want the best, go for a stainless steel header for all the benefits that has been mentioned in this thread (ignore mine :P), dont get a shiny coated one as it may be prone to cracking due to 2 different metal expansion rates...
I got a Carvox CX-990 ( aka Radiostar King-Eagle ) 2 way lcd alarm a 2 month ago. I got it installed and it was working fine. Now it got cold the remote starter will not start. It only starts when the engine is warm. What happens wile the engine is cold is: it will crank for a second and shutoff and siren goes off at that time.
I got the system on ebay and got it professionally installed all together $300+
I took it back to the shop they checked and rechecked all connections for 2hr...
