SLD type II installation manual
mokh
226
14
Hi..
anybody here have got the instruction. i search around but only found for other car. not for altezza.:banghead:
thanks
Greytezza
1,130
68
1,648
Truly Asia
Why don't you send it to a workshop that will know how to install it for you...:hmmmm:
Fix, Pay and Drive ...simple...:biggrin:
wfhan
4,339
96
selangor
grey, some of us here (including me) would like to DIY if the process is reasonably-acceptably-utterly-managable-to-d-i-y.
mokh
226
14
yup...beside, im living at the end of the world. i trust myself more than workshop around here.
Greytezza
1,130
68
1,648
Truly Asia
D.I.Y is such a simple word...but make sure when u DIY..U have a backup plan Mike...becos Murphy's Law will always happen...
Cutting and splicing the wires to your ECU is not a easy thing if you do have certain basic tools and technical knowledge.
Worst case scenario...you fry your ECU!!
I am for DIY on simple things that will not hamper your use of your car should anything happens...and make sure u make time for it....just IMHO.
wfhan
4,339
96
selangor
well, i'm a risk taker, i like to touch, feel, cut, splice, and maybe fry.... hahaha
fry ecu ar.. that would be a very valid excuse for upgrade.. :P
Greytezza
1,130
68
1,648
Truly Asia
Wah..I see someone is starting to itch already..why u neber buy the PowerFc when it was on sale..:hmmmm: You so good friend sure give discount mah...:biggrin:
mokh
226
14
or..maybe if any of u have the SLD type II installed, can give me the snapshot of the ecu and SLD connection. need few more wires to connect.:hmmmm:
hulkv6tt
210
6
guys, there is a set back with sld type II,.....
the gear change from 4 to 5 will be much earlier about 1500rpm, but it remove the speed cut perfectly....but the problem can be resolved with emanage ultimate...by setting gear shift position.:burnout:
Mokh do share with me the installation manual if u able to get it...i will do the same....currently i'am stuck to identify which pintout of solenoid A and solenoid B:mad:.....
Greytezza
1,130
68
1,648
Truly Asia
I did not have that problem...everything works as normal even the gear changing.:hmmmm:
mokh
226
14
hello world!
here come the full diagram for installation of HKS SLD Type II for our altezza.
thanks to members who help a lot in preparing the diagram and test it
this diagram for your reference only. use it on your own risks. btw, it tested already :proud:
hehe.
davidgm16
350
hello world!
hehe.
drive safe dude.. hehe.. :driver:
hulkv6tt
210
6
Yup!!!!! as tested..it's working fine,..... but need to re glue the original altezza door visor, it's cannot stand the speed...giving an annoying sound when some parts of the double sided tape start to break....
Hi ZTH Viewers...
Im having E-Manage blue for some moments.
There will be 2 indicators, 1 for "Active" and another for "Interaction". Interaction indicators are always light with yellow meanwhile Active indicators should be yellow as well only once the E-manage problem/faulty will turn to red.
Mines are always blinking orange and yellow in Active indicators, even sometimes turn red often whenever im driving. Is that a normal signal only?
And just yesterday Active indicators turns...
