sifus pls help me
yaowen.c
35
sifus...my speedometer is not working all of the sudden...the meter is not running..what can i do to fix the prob??pls help me..thanks
yaowen.c
35
roughly how much does this cost for a satria 1.3??thanks
kelvio
1,450
selangor
www.geocities.com
i change my van cable b4 around 8 bucks for the cable without labour with labour not realy sure forget edi maybe around 20 bucks
ksgoh
1,392
9
Kedah/Penang
my fren having a similar problem, however the trip and milege meter is working, just the neddle of speed not moving......in that case, changing cable will be worked too? yaowen.c, hope u don' t mind i tumpang ur thread...:p
kweng84
2,245
6
PUCHONG
www.zerotohundred.com
yaowen brother..kok weng here ar.. i changed the whole speedometer before...bout 380 bucks plus installation... sorry , in my case, changing cables also no use...
trex92
756
5,018
the meter cable is about RM100. If the odometer is moving but the speedometer is not working then it would be the whole console prob and might need to change the whole console. If both not working, means the meter cable already putus.
gloss
1,546
SJ
where did u change it?
depends, ask ur mechanic to check which one is faulty 1st.
lancer meter only cost ard RM250 include installation. but need to modi the kaki
to fit into satria / wira.
yaowen.c
35
went to the mech on sunday..he just plug back the cable at no cost...:)
kweng84
2,245
6
PUCHONG
gloss: got la..in ipoh..
yaowen: congrats!
c-ground
311
3,016
Seri Kembangan
cground.fotopic.net
please take note that, the tachometer and speedometer have no interlinking. Tacho is electromechanically driven, speedo is cable-driven.
Having a spoiled speedo and a fully functioning tacho is not an indication that the whole meter cluster is spoilt!
trex92
756
5,018
darn it, touch wood man, suddenly it is my turn liao, just noticed yesterday that my speedometer is working but my odometer keeps getting stuck and not moving... talk about bad luck....
tuckz
151
im driving a wira 1.5 fuel injection auto
my tachometer is faulty at times
Sometimes it is normal
but sometimes when i start the car, it goes straight to 4
But the meter wont go down till i shut the engine
The one showing the rpm is the tachometer right?
what seems to be the problem
the mechanic said it is normal sing mine is 2001 version
The newer one with white background and green numbers
Good day all,
My car got out about 3 weeks ago, made some changes on it.
Well, now my boost reading is zero(0) when idling, when throttle a little, it goes down....then if boost it goes up a little...
what is going on???
Also would like to know if there's any difference on NA and Turbo throttle body.
The boost meter is in working condition as i tested with few other units of meter, and it's showing the same sign.
Even if i hose it straight from the throttle body hose, still...
