Service Centre Not Using Their Own Product?
Regarding the brake pads that has been taken out, my mechanic said that on one side of the wheels, the pads are still thick while on another side, the pads are almost worn out. But the brakes are not jammed at either side.
The brake piston in the caliper is on one side, so one side push, one side pull. Probably your brakes got uneven pressure. Your mechanic should try clean and oil the floating pin....
mosesmk
165
32
Selangor
i more concern why they over tighten the Oil filter. myself normally just give bit force by hand then finish it using wrench and give 1/2 knock using rubber mallet. light knock only. never face oil leak.
RENESIS VIII
7,000 RPM
7,063
950
Ipoh
Newbie attempt to tighten the oil filter? I really have no idea why did they tighten it that tight since it needs to be removed for disposal soon.
mosesmk
165
32
Selangor
I don't see any issues, since Toyota owns Daihatsu and since you mentioned Avanza is basically a Daihatsu. Parts are inter changeable and cheaper to produce. Even in electronics, my ex company JVC say Flat Screen TV have parts from Toshiba, Sony, Panasonic and so on. There are so many parts that each individual company do not produce all of them, by themselves, but instead interchange.....lol:biggrin:
Also our smart phone. mostly LCD unit were made by Samsung Corporation.
Tighten until too over. Perhaps a wrench like you said.
Unless it is not tighten can loosen but if tighten properly, removing will be easy. If over tighten, removal can be hell. Have seen people driving a screw driver right thought the oil filter to remove it....:smokin:
sweelt
Nov 6, 2016
2,306
248
663
Penang
Oil filter wrench will do. Using screw driver might assumed thread is makan dy.:banghead:
parakey
1,367
226
663
Sometimes have to use screwdriver when it's overtightened until oil filter wrench is slipping while removing it. So far only needed to do it once
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
i use chain type oil filter wrench for difficult filter.most of it comes with very short handle so it can fit and turn in tight space. Handle is short but so far it have never failed me.Filters which are too tight will crumple but wil turn and able to be open.
Yours not tight. Have seen at mechanic even using the chain, the filter got twisted and crushed, that is why the screw driver right though it method to remove......lol
mosesmk
165
32
Selangor
Been in that situation before. wrench could not help. last choice hammer it with screw driver and turn it.
Here some DIY pic of DIY knocking to save some $$... To reduce the ugly or my car... since next year i will sray whole car.. keke...
Well i spend 5 hours doin it.. This my 1st time Knoncking... Last time i only DIY fix front bumper and knocing Front Bonnet... minor accident..
It mayb not professional look.. but 1st time now bad..
The Accident...
