i'm using bendix general CT (city driving type) it was awesome at rear...it really bites and i can do handbrake turn easily
i think it wasnt really self-adjusting because on the pad itself got one "pole"/stump to stop the piston from rotating/adjusting
the piston no.6 in diagram locked to the pad "pole"/stump
Sigh. Damn knn situation. My current car drums. Looking at possibility of converting now. HAHAHAHAAs for the brakes what I know from my mechanic, as the pads wear it locks outwards to next level, but when changing pads you need special tools to turn the piston back in. Bro. Izso will know he just bought a set of those tools...
General CT is for normal use. Bites when cold but cannot withstand too high a heat range. Using them in my wife's Chery SUV for the rear too. Very little dust compared to OE pads.
Otherwise these tools gonna stay virgin man.
Oh! yah! hero was disc, STD are drums....Sigh. Damn knn situation. My current car drums. Looking at possibility of converting now. HAHAHAHA
If not stuck hard then long nose no problem. Sometimes really need that tools....mr benard/maddriver garage also have one of those tool...
me...just use longnose plier and to extent the further fine tuning, i grind off the "stump" on the pad and adjust the caliper clearance to a very tight gap....
mine is 6 years..senndoh - how old is your car? Mine was 9 years old. Everything was stock since I swapped to rear calipers 5 years ago. Everything there is pretty much wear and tear so have to check mah.
Ah? People usually change brake pads as a pair. If they only changed one side then that service center really should be shot cuz they ripped off the old owner.mine is 6 years..
yesterday while i was checking on service records, it seems like the previous owner had the brake pad changed on rear right..couldnt find any record for the rear left tho which i think probably caused why my handbrake force is not equal..
might want to change both brakepads..
Yup, pads also comes in set of 2 pairs.....Ah? People usually change brake pads as a pair. If they only changed one side then that service center really should be shot cuz they ripped off the old owner.
izso, Nissan s13/s15 r32 front 4 / rear 2 pots calipers & discs are quite cheap now. wat else, kasi upgrade la.Sigh. Damn knn situation. My current car drums. Looking at possibility of converting now. HAHAHAHA
Engine not yet mod.....lolizso, Nissan s13/s15 r32 front 4 / rear 2 pots calipers & discs are quite cheap now. wat else, kasi upgrade la.
You slow la. Sylphy uses R32 plug and play calipers. And buy liao loo. Need you to tell me meizso, Nissan s13/s15 r32 front 4 / rear 2 pots calipers & discs are quite cheap now. wat else, kasi upgrade la.
Fulamakkkkk. STD becoming AIDS soon. Most lethal STD.You slow la. Sylphy uses R32 plug and play calipers. And buy liao loo. Need you to tell me me
Only thing is rear need more parts. Specifically the China Sylphy, that one hard to source. I've pretty much done all my R&D la. You think people like me can keep the car stock meh?
Knowing you it won't be for long......hahahahahahahaYou slow la. Sylphy uses R32 plug and play calipers. And buy liao loo. Need you to tell me me
STD also means standard, but not for long.......Fulamakkkkk. STD becoming AIDS soon. Most lethal STD.
