haha logical enough...cos that was my theory only cucuk at the oil return pipe...Hey danz i see in google they say cucuk at the ATF oil pan and the sensor adaptor usually they sell outside is very big in diameter for the ATF hose
That's a bloody good DIY! If you buy this kit get me one too! I'll pass you the $ before handNo answers? I ran across this and might as well share it here.
What do u guys think?
DIYautoFTW Forums - Joel's DIY Budget Oil Temp Gauge by JDwhiteWRX
Good find....:top:No answers? I ran across this and might as well share it here.
if want proper then can get the adaptor fit at piping...or even better if custom adaptor at the oil coolerhaha logical enough...cos that was my theory only cucuk at the oil return pipe...
Actually which is best place, as different place will show different results....:hmmmm:if want proper then can get the adaptor fit at piping...or even better if custom adaptor at the oil cooler
Actually which is best place, as different place will should different results....:hmmmm:
Can try those epoxy glue?That temp meter is about RM26.50. Cheap and nicer looking than Defi gauges imo. ahhaha
What i'm worried about is the way he held the sensor, silicone will slide out after sometime in my experience.
And mine wasn't even 100 Celsius.
And I want to know the current temperature of the transmission, where do u guys thing I should put in?
