Buying a Perdana
pathfinder
231
Hi
Im in need for a 2nd car ...with limited budget. I don't want to finance/loan. So, Perdana is right candidate. ..roomy, comfort, sufficient power and affordable spareparts.
Max budget rm10k
Should i go for SEi non v6 or better v6? V6 is sweet engine. But a bit afraid of extra maintenance. Even after Proton fitted atf cooler, the gearbox still problematic or not? Other than gearbox, what are common problem?
For SEi non V6, what is last production year?
Please give some comments on SEi vs V6
Thank you
RENESIS VIII
7,000 RPM
7,063
950
Ipoh
Perdana SEI last production year is on 1998.
I think in my opinion, SEI is the cheaper option to maintain since it is using an inline 4 engine compared to V6. V6 engine definitely requires a higher maintenance costs due to 2 extra cylinders. Workmanship costs for V6 is also higher than SEI.
Look at it this way.
4G63 SOHC (SEI) VS 6A12 DOHC (V6)
1 Cylinder head VS 2 Cylinder Heads
4 Pistons VS 6 Pistons
1 Camshaft VS 4 Camshafts
1 Cam pulley VS 4 Cam pulleys
1 Exhaust manifold VS 2 Exhaust manifolds
DanzEterna
15,911
3,371
3,213
PJ
www.primeperdanaclub.com
12valve vs 24 valve
4 spark plugs vs 6 spark plugs (workmanship is expensive to remove the rear plugs)
pathfinder
231
Haha..Thanks guys
V6 is cheap now. So tempted
Both SEi and V6 engine are reliable?
Any problematic sensors?
Spark plugs cost to change maybe can use expensive plugs, change every 80,000km = 3 years
Any tricks to enhanced gearbox reliability?
Maybe use fully synthetic atf and larger atf cooler?
pathfinder
231
Hi
Original V6 absorbers made by Kayaba or Apm ?
Anyway...which lowering is best? lower but acceptable comfort ride
kurt_629
872
54
528
johor
Once lowered the travel is less, comfort sure less dy......
yeah.. not forgetting you need to change lower arms, drive shaft etc..
every year, its becoming a part of the SOP.
my mechanic told me yesterday that my drive shaft is gone again..
3 set within 3 years..
I guess it must the kampong road that is killing them..
high hump + lowered = spend $
Hi all,
I'm planning to use Mivec Head with local 4g92p block, together with the mivec piston. As we all know mivec block already equipped with oil squirter, which is opposite to 4g92p,my question is;
a) Can the local 4g92p block handle the pressure from the mivec system,
b) Can I installed oil squirter on 4g92p block?
Hope to hear some positive feedback.
