NBTD - I'm BORED
nw111
81
34
518
Terra dei Motori
how can read and reply to this forum using smartphone? What app do you use?
Got app meh? Used to browse ZTH on Tapatalk but now not anymore because I can't find it there.
Tom
TIMETOATTACK
Jul 6, 2000
5,562
3,229
Try loading on your mobile browser, there's a mobile mode for phones and it works like it's in an app
So there's an app that supports forums like this one, called tapatalk like @nw111 said
it lets you manage multiple forums in one place
do you still use Tapatalk? does it give you a better experience?
can explore adding back the function again actually
Tom
TIMETOATTACK
Jul 6, 2000
5,562
3,229
by the way guys,
The replies per page has been set to 50 instead of the previous 20 per page.
Now there's more to read before needing to click to the next page, works better for mobile
What do you think? Can we go 100 per page?
  • Like
Reactions: Izso
by the way guys,
50 doesn't seem to slow down the loading time. Maybe we can trial run the 100
  • Like
Reactions: Tom
leinnz
333
57
3,028
slow slow la. i am still H here. no 4g or 5g yet.
nw111
81
34
518
Terra dei Motori
Still does but I can't really tell if browsing via Tapatalk gave me a better experience compared to mobile browser because I didn't browse ZTH on Tapatalk long enough to judge whether it's better than the browser.
Current mobile mode is great as it is but I don't mind having it back on Tapatalk though.
Tom
TIMETOATTACK
Jul 6, 2000
5,562
3,229
thanks, will check the latest tapatalk, one good thing about it is the push notifications rather than the current email
minibeany
598
102
543
i downloaded Tapatalk but couldn't find this forum.
Last time I used Feedly before and subscribe the RSS. Let me try this again.
Tom
TIMETOATTACK
Jul 6, 2000
5,562
3,229
Thanks guys, we're back on the Tapatalk app :) give it a try
  • Like
Reactions: minibeany
nw111
81
34
518
Terra dei Motori
Testing. The notification for this thread just popped up on my screen.
Sent from my M2007J20CG using Tapatalk
gunnerzz
Jul 3, 2014
2,109
695
713
38
Melaka
Additional job on my Pajero.
New set of front discs went on.
Parts arrived on Thusrsday and cost just slightly above RM 200 inclusive postage.
New pads ( Trestor Organic model@ RM40 ) went on.
I did not take a step by step picture as i was pushing to complete the job ( which i failed ) before noon on Friday and i started at about 9am on that day. Never underestimate a simple job...hahaha
Why it took soo long to complete?
1.Need to remove 6 lug nuts.
2.Remove 6 10mm bolt holding the front hub locker.
3.Remove the circular pin holding the driveshaft in the hub locker.
4.Remove 2 screw holding the wheel bearing lock in place.
4.Remove 6 14mm bolt holding the disc+hub assembly.
5.Remove 2 17mm and 1 10mm bolt holding the caliper and the disc cover.
6.Once the disc+hub is out, need to remove another 6 14mm bolt+nut holding the assembly together.
7.Need to push the piston back in a lot further than usual as new disc is a lot thicker.
8.While at it, took the time to re grease the front wheel bearing.
All the above plus fasting month is not a good combo, even my impact wrench felt double its original weight...that plus the Pajero parts which most of the time weight double compared to any car parts.
Next for the Pajero?
Aircond service. Already got an estimate and it will be about RM250. Wont be a DIY job.
I did try to upload the finish pic but failed. Not sure if the size is too big.
  • Like
Reactions: Izso
My Wira radiator needs to be changed, am tempted to change it myself, been looking for service manuals for the Wira, but no luck. So has anybody tried this out? What should i be careful of? Any advice is welcomed. Thanks.
Btw its a 1.5 manual.
