Myvi OD light blinking
joshualee
86
1,508
I am also facing such issue.. Still no solution found up to now.. Am worried after changing GB problem still occur.. Any idea if changing to Manual Gearbox will do any good?
Pretty sure changing to a manual will completely remove the blinking light altogether. Manuals don't have TCUs afterall....
joshualee
86
1,508
Because after all the hassle changing timing chain and diagnose.. Seems like no solution at all.. Guess its best to just change to manual.. :hmmmm:
ixeo
4,788
3,080
KL, Malaysia
Could be
1. The connector for the gearbox loose/wet/sot
2. The sensor/solenoid problem
3. TCU rosak
Nov 3, 2017
Hi guys, my Myvi 1.3 (2010) is having the same issue, OD light & Engine light blinking, brought to the workshop they checked and reset the ECU and changed the (Input) & (Output) socket which connects to the engine, it was fine for A DAY, and the issue occurs again, I've checked with few other foreman regarding my matter, they claim it must be timing chain...
Check engine lights comes on need to use diagnostic machine to find the fault code...
wsonny
467
14
5,018
Ampang
After so many years now only i solve this problem by changing whole unit solenoid cost less then RM400. lucky didnt really go to change the timing chain or gearbox
  • Like
Reactions: Izso
