It's time to let it go......
Did you know that GTT only has 250hp? And on wheel is around 180-190whp. Coupe with the body of over 1600kgs, the performance is similar to Airtrek in stock. My tuner has tuned many GTT or even GTRs, they regards them as sluggish and slow. Well, that is IF it's stock.
However the RB25DET or RB26DETT has loads of potential. With proper mods, they can FLY!
In a way, a Wira with 4G63T can be even faster than your Airtrek?
RB25DET and RB26DETT both have a high threshold limit for their engines... I think 600hp is possible with stock internals... 4G63T will have a hard time to reach such figures...
A wira with 4G63T is not considered slightly modded.....lol
One time my VR send for alignment, the tyre shop boss was also doing a wira with 4G63T. After he finished both cars and the wira left, he told me that wira got VR engine but is so light, so feel much more power than my VR with super saloon body.... :smokin:
I mean he said his 4G63T is just slightly modded. Din't do major mods to the engine.
I hope someday I can get the opportunity to have a ride in 4G63T Wira... My experience in ridding modded car is B18C Civic EG hatch and EJ20 twin turbo Legacy auto but that was just cruising only...
Yup, if always do pick up, heard many have crack in chassis........
My favorite activity when driving. Guess I'm not suitable for that engine. :rofl:
My friends who are not used to sitting in manual cars are always frightened during pick up.
Wira chassis is only around 1000kgs and mate with a VR, that's like 240hp/ton. It;s too much actually and the chassis will not be able to take it. It's dangerous IMHO.
Yes that's very true...that's y I kept it close to stock n mainly concentrated on d braking n suspension system (I trial n error d absorbers 7x before I got d rite set up)..I upgraded to bigger discs n better pads...I also had d chassis fully seam welded (d advantage of running own body/paint shop hehe)..n apart from some bars for extra peace of mind...:)
I'm not so much into straight line aka drag but more to curcuit driving aka winding/corners..that's y I retained stock oem internals for more reliability..
Your Wira seems well balanced. Original chassis is from which Wira? Standard ones or C99? I think even by keeping the 4G63T, power is very much enough for a lightweight Wira. Pushing out more power will probably affect handling and grip because of torque steer I guess...
I guess you are very particular and sensitive towards handling, suspension tuning and tyre choice?
Original body from 1.5 hehe..that's y lots of work as listed had to be done..n more work...:)
Yeah u might say I'm very particular about d handling/suspension n braking systems...no point having all that power if u x control it aka handling n stopping rite..I learned my lesson from my integra incident..
But then again like I said I'm x much into straight/drag so I x really need much power...just main focus more on d handling n braking...:)
N oh ya tire wise I x afford d UHP so I settle for mid range (at least in my opinion they are la hehe)...my last set was kumho (x remember d model tho)/nexen (n8000) combo..x too bad actually (oso at least in my opinion)..
4G63T also capable of 600bhp. Saw one VRC members car with huge turbine, Inlet manifold was longer than the engine, and with NOS.....:smokin:
Yes definately if Airtrek is stock. In stock, no doubt the engine spec says 240hp but in reality, it will be around 220hp. Then with the sluggish power robbing gearbox, you only get 160-180whp in stock. And with that, it has to push over 1600kgs++. 0-100 in stock was achieved in 8.5-9 secs. It was slow in stock. Similarly to GTT, it's heavy and slow.
However who will drive a stock Skyline? Airtrek maybe but definitely not Skyline :)
My Airtrek 0-100kph in Drive was around 5.9 secs. I reckon it can go faster if I use manual and that was even before I had the downpipe and fine tuning done. It was 1.2 bar of boost.
My mods ends at around 270whp + 350Nm wtq @ 1.5 bar.
The 4G63T has a lot of potential but before it could reach 500hp mark, internal must be upgraded. With stock, the most you can reach is 400-450hp.
Indeed a lot of work needs to be done to reinforce the normal 1.5 chassis. Brakes you are using Evo 3 twin pot or even better brakes?
So, you're not running performance tyres on your Wira evo last time?
If got a lot of money for custom or forged parts, 600hp sure can... Even some drag cars on western countries or Australia claims that 4G63T can give out 1000hp.... But I think if want to compared with Nissan RB engines with same output, probably RB are more reliable since the stress on the engine is lesser than 4G63T?
Bone stock Airtrek turbo seems quite slow for a performance car. If compared to other SUV, that is quite good... But with that spec, I'm afraid perhaps even a B18CR VTEC engine might just outrun it...
Your whp is 270 then how much are you having at crank? Should be over 300 since your AT gearbox does cause a higher amount of power loss...
True, heard about this before. 4 pistons and 2 litre engine, sure need to upgrade internals if want to push it that high. Unlike RB25 or RB26 with 6 pistons and larger displacement.
I got 260whp and 34x wheel torque with my bone stock e3 in my Wira at 1.2 bar and it feels scary already ~_~ Not to mention with 15" tyres XD
I once saw someone posted Satria 4G63T here with claims of engine modded until 450hp. I think that is a bit too over and scary since you said yours at 260whp feels scary...
It's too much power for your front wheels to take if yours is 2WD. 130whp per wheel on 15" is just too much.
Anyway, dyno'ing 2WD vs. AWD is very different. The 2WD setup will always get more output comparing to AWD. What I mean is the 2WD 200whp and AWD 200whp are totally 2 different ratings of power output. Yes, the AWD actually produces more power in this sense.
Because powers are distributed to all four wheels instead of two in the case of 4WD right? Hence, the power loss on wheel is higher on 4WD I guess?
I've heard 4G63T hitting above 1500hp, so it isn't a surprise.
Yes bone stock Airtrek is slow compared to B18C. But the torque is more, so pickup 0-100 may lose but it will catch up from behind.
With 270whp, it's estimated around 330hp in crank.
Yes... do you know that by removing the rear lsd box, rear drive shafts and center shaft, Airtrek is able to loose about 100kgs! Yes those weight + friction from moving parts, it's actually more power. Just a simple comparison but not real figures. Eg: 2WD 200whp = 240hp in crank vs. AWD 200whp = 260hp in crank.
Power is something, but ability to put it onto the road is another thing. I have done a drag race with an Optima Evo 4 before. Back then, I was still using stock engine with just full exhaust, raised boost (0.6 to 1.1 bar) and steel intercooler piping with top mount intercooler. On all 3 runs, I was ahead. Not because my car was more powerful. He was literally spinning wheel when I took off.
Yup, considering going 17" in the future but not now yet
That heavy? This explains why Evo 1,2,3 are around 1200kg which is like 200kg heavier than Wira. The 4WD parts, heavier engine and perhaps the reinforced chassis.
Yes, I know about 4WD having much better grip on the road compared to 2WD. For a 4WD machine to launch during start, it is much easier than 2WD. For 2WD, you really need to time your RPM right before launching or else you'll risk losing grip and wheel spin. Grip and acceleration is one reason why I like 4WD cars compared to 2WD. I like cars like Evo, STI, Skyline GT-R...
Are you referring to this Optima Evo? Because I remember seeing an Optima Evo here before.
http://www.zerotohundred.com/newforums/showthread.php?t=426863
A thread every 60 seconds
