i'm using ford laser s with B8t... is there any other breaking system that i can change....but i dont want to change from 4 lug to 5 lug cause need to change rims to...sifus all aroung pls need advise here...thank you..
yo there did you get the nasional disc for such a guud price?Khorne said:Basically you can opt for better disc with crossed drilled and ventilated passages... National has them and so do RunStop... I paid RM 420 for the front pair... Also opt for steel braided hoses and a good set of pads...
There arent many other options unless youre willing to fork uot a large amount of money and install either aftermarket brakes or those form a RX7 FC or VR4 twin pot...
But remember if you opt for bigger brakes you might just screw up the brake bias...
CHEERS
hi dude,fresh.com said:i'm using ford laser s with B8t... is there any other breaking system that i can change....but i dont want to change from 4 lug to 5 lug cause need to change rims to...sifus all aroung pls need advise here...thank you..
dont know where skyzone is more info would be great for cheaper alternative.Khorne said:I didn't get the National disc...
I got Runstop...
Dun think they have it for your car bro...
But you can call SkyZone...
CHEERS
bro do u mean that get a vr4 single pot disc only...and compile it with our b8 180 calipers..???Khorne said:Ford Laser S, Why not go for the B8 180 calipers with VR4 single pot disc...
Been hearing alot of good reviews about it from people who has done it...
Check out the B6B8 website for more info...
CHEERS
EXACTLY that... You understood what I wrote, but then you still ask??? :Not_Impressed:fresh.com said:bro do u mean that get a vr4 single pot disc only...and compile it with our b8 180 calipers..???
