Why pening? U welded it? :vroam:jack? what kinda jack?
stpdcar, no vapour last time i jacked up the bonnet for 4 years.
now still pening how to remove the bolt only..
Try to use bolt extractorhow to add another bolt when the thread on the head already gone?cant remove the old. its like the whole thing is very soft and rapuh, so the spannar cant get a grip on it.
. in u'r case, use those mini monkey wrench those plumbing use coz u know how it grips the pipes rite. if stubborn oso, use grinder, cut flush wit hood, use drill to drill self tapping scew(screw can drill through metal, common hw should have) half way, use a blunt screw, screw in & hopefulle the bolt moves oso, still stubborn, need to drill the bolt off. worst case scenario, u've drilled the hood thread, welding another nut flush wit new hole & wallah new thread. make sure afterwards use grease for the bolt & nut coz water sure rust them if exposedhow to add another bolt when the thread on the head already gone?cant remove the old. its like the whole thing is very soft and rapuh, so the spannar cant get a grip on it.
sure can use this method, but i'm sure the reverse groove head is quite hard to find here though unless u've seen it b4, i would like to know where coz sure wanna get 1You can use this method to remove the bolt
[youtube]Screw extractor | easyout | broken bolt removal - YouTube[/youtube]
Another method is to use this tool.sure can use this method, but i'm sure the reverse groove head is quite hard to find here though unless u've seen it b4, i would like to know where coz sure wanna get 1
ideal & easy but a bit expensive for sumthing seldom use, later forget & lost cry out loud
Easy. Buy, use, keep, wife complain, sell to Izso cheap cheap.ideal & easy but a bit expensive for sumthing seldom use, later forget & lost cry out loud
can no problem, later when meet edi, will alwez meet wit u than borro this borro that hehehEasy. Buy, use, keep, wife complain, sell to Izso cheap cheap.
hows ur alja? done it?i wanna DIY this on my ALJA, cos alja mia engine damn hot always.... edi put 2 CAI hose oso same blardy thing n still hot
driver modified too kao kao already la. Engine cannot cope with the driver modifiednessi wanna DIY this on my ALJA, cos alja mia engine damn hot always.... edi put 2 CAI hose oso same blardy thing n still hot
