twistedichc
the world is not chee sin maa, drivers rIts a craaaazzzzyyy world out there.
Look at chassis not E39A also kantoi already la. But don't know whether are the JPJ officers that skilled or not.if unker convert 4wd, jpj wont know cos ori vr4 is originally 4wd ma. unless they look at the geran then kantoi la
Oh, meaning like having the gearbox but the rear parts to drive the rear wheels is removed?The gearbox is the same unit whether fitting in as 4WD or 2WD. For 2WD, have to weld the rear drive so power transmit to front. To have 4WD have to install the long shaft, rear drive shaft and also the petrol tank have to be changed to accommodate the long shaft running to the rear. Of course the rear assembly all have to change as 2WD rear is torsion beam...
---------- Post added at 09:45 AM ---------- 6 hour anti-bump limit - Previous post was at 09:43 AM ----------
Your 6A12TT was 4WD right?
There are people using 4WD Perdana also out there. But which 4WD system they are using? From Evo or from E84A/E74A Galant VR-4? And those JPJ officers really squat down to check the under body of the car during roadblock?no 2wd only, locked from 4wd - 2wd but running on evo gbox la.
More like humanity. Pollution, War, Killing and all that going on. It's a miracle if our planet can survive if all these continues.the world is not chee sin maa, drivers r
Yup, when we buy half cut you get the front only, so even wire harness have to join below driver seat.Oh, meaning like having the gearbox but the rear parts to drive the rear wheels is removed?
Rear cuts are usually sold cheaper right? But the demand for rear cut is not much I think.Yup, when we buy half cut you get the front only, so even wire harness have to join below driver seat.
Rear not touch for undercarraige.
If 4WD then got to buy rear half cut too, then you get the rear parts....
Yup, special cases and especially if need 4WD....They won't bring the rears only.....Rear cuts are usually sold cheaper right? But the demand for rear cut is not much I think.
