- Mar 1, 2009
- 97
- 16
- 1,508
Hi Guys,
I've recently decided i'm not happy with the power my Evo 8 MR is making, its currently running about 320 at the wheels (although there is an issue with a lazy tappet causing it to only run at 280). I'm running high cams, straight through exhaust, blow off valve etc... I want to squeeze some more power out of the car with simple and cheap (but effective) mods. I don't want to go spending alot of money on the car and i can't run higher boost (1.8) as this has been done before and the turbo went BOOM! I also don't want to put a bigger turbo in either as the current turbo is so responsive and has virtually no lag so i don't want to effect that. Could you guys possibly give me some possible suggestions to bump power up to about 350 - 370 at the wheels...
Thanks
Thanks
