HELP! Wira Idling problem, mmc model
Anyway, you appear in that posting. wahlao...my face turn blue d.
Turn blue, breathe, breathe....hhahhaha
Hello, remember I size 11 you size 12 shoe, so I don't think I can attempt anything......hhahhahahhahhahahhahha :rofl::rofl:
sweelt
Nov 6, 2016
2,306
248
663
Penang
my slot in question again. my wira 93T.
have all the symptom stated above at early part after swapping engine.
Some troubleshooting i do it myself. ISC replaced. TPS adjust according to online manuals (resistance continuity reading).
BISS screw adjustment made. Before change ISC, BISS near full open. Now fews round from close position.
Cold start 1500rpm slowly drop to 700-750rpm.
ON air-con rpm jump to 950rpm. Drop to 550rpm when compressor kick in, then up to 900rpm. ISC is working.
After drive for 1-2 hrs, normal one. OFF engine.
When start back the engine after 1/2hr (warm start), rpm stay low. 550-600rpm. vibrate.
ON air-con, all back to normal. OFF air-con, car idle normal.
I got read from pomen_gtr about oil filler cap leaking. Cause irregular idle.
Pls help me to continue further my diagnostic. Thanks sifu.
Dear sifu. Pls help me how to diagnose warm start low idle.
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
there is another BSS screw inside the stepper motor...try re-adjust that first...make it almost closed...
Get Dimensions
Width = 9.2
Height = 4.8
Switch
height - 1.9
width - 1.4
Get Materials.
Preferably Aluminium Sheet 0.7 mm or less. . Plexiglass might crack while cutting(Unless you have sum advanced Laser cutting machine.:p) If you're from Seremban, You can get this from Tukang besi..corner shop same row with Dunlop Tyre Shop in Temiang.. Right in front of the Traffic Light
Switches
Prepare...
