help! battery mati
weikhee86
423
hey guys my battery baru died down last 2 weeks..then send for recharging and stuff..now this morning wanna start the car battery mati again...my battery got smth wrong o what? need to change new battery? the guy at the shop said the battery is a little weak nia and he said the problem might come from starter motor..all along my starter motor never got problem one...is it battery problem o what? o the starter motor's carbon finish?
SkYwAlKeR
10,139
300
ePoh ~ malacca
ur house got multimeter??... use it and check the voltage of ur battery.... if alot means ur starter problem lo...
usually recharged battery cannot tahan for long compare to brand new ones... but 2weeks is rather fast.... check all ur connections and make sure no short circuit or heavy loads....
weikhee86
423
skywalker,
thanks for the info...i took my battery to the shop and ask them to recharge for me..come back the car can start. Drove for a while then battery died again. My house no multimeter wor...hey skywalker ask u smth ok? if grounding done wrongly will short circuit one ka? o faulty VS? plz enlighten me bro..thanks..can u tell me good grounding point? my grounding kit has 5 wires...where to ground?
gohkokeng
2,443
battery mati and help it?
buy coffin for it loh if u want and burry it maybe somewhere near the garden?
Speed Demon
325
Selangor
www.freewebs.com
Black Samurai is correct. The alternator is used to recharge battery, otherwise the current produced by the battery is used up. Bring your car to a workshop which has a multimeter and make them check your alternator.
I do not see how grounding wires or starter motors can affect your battery life.
Read this article and other related links to understand things better: http://auto.howstuffworks.com/question324.htm
386
SABAH
www.irs-asia.com
Check your alternator. If it's working fine, then check on your wiring. My friend's car battery mati every week, last last baru tau his sound system wire "sot".
sakuraguy
5,000 RPM
5,834
27
Sendai, JAPAN.
www.zerotohundred.com
weikhee86 : If a battery's inner platters "kembung" u cant recharge it, if u recharge also no point because the charging wont last long.
I dont think alternator's mistake .. replace ure battery .. :)
weikhee86
423
thanks for the advice sakuraguy..i changed my battery already..the old one sucks and i sold it off for 5 bucks..:D
Speed Demon
325
Selangor
www.freewebs.com
So confirmed it was the battery and nothing else? What brand is the battery? How old was it? Let us know so we can avoid buying that brand! :regular_smile:
sakuraguy
5,000 RPM
5,834
27
Sendai, JAPAN.
I always use Century .. sometimes careful when u buy battery .. avoid often using battery power without starting the car, like putting ICE loud for long without engine on.
Battery maintenance can last longer .. mine is now 2 1/2 years and still working fine at 12.5v IGNITION and 13v - 14v travelling mode
Nieto
494
buy battery no waranty ka? if battery faulth, da battery company will replace a new 1 for u~
Last application of OCW was on 31/3(1 week ago) and washed my ride on Sunday 8/4 with the normal 2 bucket wash spiked with ONR. After the wash just an application of OID(using less is more). Used the car the following day to work as usual... no rain. The next day to work which is a Tuesday, it was raining in the morning and you all know what happen when the rain stops... you get SANDY ROAD plus free sand blasting from other drivers on your way to work. BUT during the lunch hour i took my...
