Ferrari Unveils F2008
keshy
528
698
1,593
Ferrari has officially launched their Championship defending machine dubbed the F2008. It is also the fifty fourth single seater built by Ferrari specifically to take part in the Formula 1 World Championship.
The design, codenamed internally as the 659, represents the Scuderia’s interpretation of the regulations for the 2008 season. A major new element in the regulations of 2008 is the introduction of a new electronic system to be used by all teams known as SECU (Standard Electronic Control Unit) which is ironically produced by Mclaren Electronic Systems (MES). Other areas affected by rule changes are: Gearbox, which must now last four races, Safety, with the introduction of a higher side protection around the driver’s helmet; Materials, with a limit to the type of composites that can be used.
As a result of these rules, there has been an increase in the weight of the car. All aerodynamics have been completely revised. The car is due for an intensive and all encompassing development programme which will run throughout the season. The monocoque has been further cut away under the driver’s legs and the side pods and engine cover are more tapered. The suspension system has been reworked and developed around the new aerodynamics.
The wheelbase and weight distribution have been adapted to the new regulations and on the basis of lessons learned last year in terms of the performance of the Bridgestone tyres. Changes to the technical and sporting regulations in terms of electronics, alongside the introduction of the SECU, have led to the removal of a host of a driver aids, such as traction control and engine breaking and the electronically assisted starting system, and also mean that management of the differential, engine and gearchange are much simpler. The gearbox casing is produced in carbon, while the transmission continues to be mounted longitudinally. For the second consecutive year the gearchange is fitted with a quick shift system, adapted to the SECU software and further speeded up. In dealing with the reliability aspect of the new regulations, Shell has played a key role in defining the lubricants for the gearbox. Meanwhile, the braking system has been updated with new callipers and innovative concepts regarding cooling.
The 056 engine is mounted longitudinally and continues as a load bearing element. Its basic structure remains unchanged compared to the unit homologated at the start of last season, while its auxiliary systems, air and fuel intakes have been further developed. The technical regulations also call for the use of fuel corresponding to European Union norms, with a content of components derived from biological sources equal to 5.75%. As usual, during the design and development stages of the entire car, our technical partners played an important role. Apart from previously mentioned significant input from Shell , also worthy of note is the contribution of the Fiat Research Centre, especially in providing simulation systems and Brembo for its work in developing the braking system. As is now traditional, a great deal of attention was paid to the performance and optimising of the materials used at the design stage and through quality control, striving to maximise performance levels while attaining the highest possible safety standards.
TECHNICAL SPECIFICATIONS
Chassis
Carbon-fibre and honeycomb
composite structure
Ferrari longitudinal gearbox
Limited-slip differential
Semiautomatic sequential
electronically controlled gearbox
quick-shift
Number of gears: 7 + Reverse
Ventiled carbon-fibre
disc brakes
Independent suspension,
push-rod activated torsion
springs front and rear
Weight (with water, lubricant and driver): 605 kg
BBS Wheels (front and rear): 13''
Engine
Type: 056
Number of cylinders: 8
Cylinder block in cast
aluminium: V 90°
Number of valves: 32
Pneumatic distribution
Total displacement: 2398 cm3
Piston bore: 98 mm
Weight: <95 kg
Magneti Marelli digital electronic injection
Magneti Marelli static
electronic ignition
Fuel: Shell V-Power ULG 64
Lubrcant: Shell SL-1098
drMpower
409
7
given the episods of recent F1 circus, surely they gonna change the paint from RED to SILVER AND BLACK
hahhaahahahahah
Just wondering, Powerzone carry any twin carb preferbly webber and have the connector for Nissan GA16 series engines? If so, how much both new and recon ? Thanks.
