Experience on Toyo T1R?
davidcnz
808
102
1,543
Malaysia
Anyone ever used Toyo T1R tyres? How is it?
Please give me some feedback on this tyre..:biggrin:
looper
Jul 11, 2010
22
503
the tyre for me is quite good on both wet and dry. Grips really well. However its a bit noisy though. I've only used it for 25k until one of my tyre bulged due to hitting a pothole:banghead: Only noticed it when the car starts vibrating at 140km/h. huhu. I was using 225/35/19. Now im on Toyo T1 Sport. Seems its a new design with a harder sidewall. So far so good with it. :biggrin:
davidcnz
808
102
1,543
Malaysia
Thanks for the reviews bro ! :) appreciate it ! how much will a Toyo T1 Sport cost for 225/40/18 ? any recommend shop ?
Try these shops...
E.D. Tyre Autocare Sdn. Bhd.
24, Jalan Utas A
Section 15
40000 Shah Alam
Tel: 5510 0620
Fax: 5511 0820
HupShun Tyres Auto Car Care Sdn. Bhd.
11, Jln. PJS11/7, Bandar Sunway
46150 Petaling Jaya
Tel: 03-5632 9926 , 5637 2275
If not, then Klang shops.....
Glory_manunited
54
508
I think this Tyre is very good even in dry and wet condition...it has good temperature profile for Malaysia road and its quite soft making it grips more to the road (I'm using 195/55/15)...but the problems with this Tyre is it side area in the red box marking...it seems that the wear and tear in this area is quite fast compare to other area...don't know what's the problem but all my friends are having the same problem. :hmmmm2:
AD_EG
6,000 RPM
6,328
231
Ipoh
excellent tires...good grip wet n dry.
like bro glory mentioned. that particular part wears of quickly. and the threadware quite high.
If you look properly, the pattern depth there is very shallow, that is why you face that problem...
For me, compared to others tyres used, the wet grip looses out slightly as I tent to wheel spin in the wet.....and sidewall also too soft for me....
Ello guys,just recently converted to Mira L200s. No Blow off valve.
I've a question regarding the small hose connected to the air filter box. A fren of mine suggested that i cabut the hose from the box and then connect a breather to it.
Wats the difference between connecting the hose to the box or a breather? Besides louder keppish,keppish(when connected to a breather)? Like, are there any drawbacks?
Thanks in advance. :)
