DIY timer
CyberPunk
324
Subang
www.cyberpunk.co.nr
Dear sifus,
any idea if i could DIY a timer for the air-cond fan to spin after i turn off the engine?
my idea was to cool down the engine/engine bay with just only the air-cond fan... means like after u turn off ur engine, of course la the engine compartment will be hot, so if there's such thing as a timer to make ur fan to spin and blow air into ur engine compartment to cool down ur system? :)
jaywat
1,329
I don't think can lar, the fan blows towards the heat sink only, even u turn it on it has no effect on venting the heat off the engine.
kruger
521
A.Setar
can lar jaywat... i think just buy count down timer module from the electronic shop. then use relay to tap to the batt and the module. then you think some more on your own lar.... thats is my opinion only... if don't understand the wiring of the relay, you can ask acc shop to do for you lar... but you must diy the module yourself first. ;)
ftzone
full throttle zone
5,339
141
3,163
Penang, Prai
www.ftzoneracing.com
u can opt to get an aftermarket turbo timer... for the looks, style and convenience of installation.. but wiring maybe you'll have to refer to a technician. nowadays timer cap ayam pivot look a like is only around RM98
jaywat
1,329
Okay, after i read it another time i got the point already. Cyberpunk, u should state that u wanna vent out the heat through air con fan mar...yea, it's possible lar, like kruger said, get a countdown module with relay to kick start the fan when it detect ur engine off and count from 20 to 0 sec to off the fan maybe. How? don't know also. If not sure, get ftzone's suggestion i think he is selling related stuff :D
kruger
521
A.Setar
yeah he's selling that stuff... nice guy also if you talk to him... ;) can get more discount ma... if i puji sikit... hehehe ;):D
ftzone
full throttle zone
5,339
141
3,163
Penang, Prai
apala... eventho i'm selling those stuffs.. but it's your money and choice mah... kruger will meet u today after my boss finish screwing me.. hehehe
sometime people like to DIY instead of buying straight ma. i understand 1... but if u fed up DIY already u can consider my product pulak.. hahahahaha
CyberPunk
324
Subang
www.cyberpunk.co.nr
hahaha... yeah but i heard a car without tourbo installing turbo timer is a waste of money and it does nothing much... as we know turbo will heat up the engine and the exhaust and anyplace that connects to exhaust or something... then with turbo timer it will let ur engine run for a little while to release the heat from inside to outside via exhaust.
but what my point now is to blow off the heat in the engine compartment and not inside the engine... so air-con fan will do... my car has 2 big air con fans so i thought it would be useful if i can activate those fans without turning on my car to blow off the heat from my engine bay...
well i got this idea from my aunt's old accord 2.0i...
if anyone knows the circuit can share share hor... =P
thanks guys! u guys rules....
ftzone... haha.. that's a last resort to go for u =P
ftzone
full throttle zone
5,339
141
3,163
Penang, Prai
no la cyber punk.. what i mean is use the turbo timer to connect just to the fan la... not the ignition... aiyo.. u misunderstand liao. but how to wire it to function that way.. i dunno liao.. have to ask a professional.
kruger
521
A.Setar
if you build your own timer, you should know where to connect it lor... but if you buy the aftermarket timer they will give you the wiring diagram, so you will know some of the basic of the connections that you can use. like ftzone said, timer pivot cap ayam brand now a day will cost you just rm98 with good looking lagi tu.... :p
www
29
kl
hai.. i'm newbie here. we can diy simple timer less than rm20. buy part and assemble. but no brand and box lar...
hi guys..my side window glass got few lines of scratches due to window bracket :(.. i've heard there's one chemical/solution/liquid tht can recover these scracth marks..anyone heard of it? where can i get those?
thanks a bunch!
cheers!
