DIY repair water leaking
sam1741
1,188
hi all
if i not mistaken there is one black thing
kinda feel like soft rubber one
can i use that to fix water leaking?
what is that thing called?
anyone got other idea about fix water leaking?
hope can share share here.... i wish i can DIY
thanks in advance
netmatrix
2,255
42
P Jaya:Malaysia
kh_tan.tripod.com
Hi Sam1741,
The thing you want to stop window leaks is silicone. You can buy this at Hypermarkets also. I hope i can post pictures of how i did it here. I'm starting on it this Saturday. I'm fed up with the leaks too.
traize
519
5
buy frm ace hardware colour is slear so if u put on body ppl wont perasan instead of black
loose_end
3,649
197
Malaysia
Go any hardware shop also can buy lah , got transparent colour , white colour , black colour also..Buy the silicone tube and the silicon gun..izzit the one you mean use in aquariums ??..
wael
84
www.mypanoramic.com
which part of your car body are leak. it may be different solution to fix any water leak on car body such as windows or doors etc
kent75
972
Cheras, KL
Some of the black silicon u can find in hardware shop , we call it 7 star gel (Cantonese=cat sing gou).
ExODus
463
What if the leakage comes from the rear trunk rubber? Change already to new one... Still got leakage... need to silicone the rubber? or glue it to the body?
loose_end
3,649
197
Malaysia
Silicone and glue..but then , silicon would be tidy unless it is not exposed..
traize
519
5
use silico, yes it can be messy tht why i ask u to buy the clear type silicon so it wont be seen (compare to black)
Dudes ,
i'm new here and i need some advice..
(1)putra and gti are using 1.8 engines,but are they the same
specs? or gti more powerful?.
(2)in terms of performance(stock egine) which is the best?
their bhp? max speed? power-weight ratio?
(3)im planning to buy a second-hand either gti or putra..
a year 2000 gti price range around 45000-49000 while a
1999/2000 putra would only set me around 40000-45000..
which is more worthy?
hope to hear soon..
tq~
