Bro,E-Tech, how about P08, which capacitor or anything else need to replace to avoid any future failure? Thanks...
Peng,VERY GOOD LESSON FROM U BRO...E TECH...TQ![]()
hehe.... not bad la.. if max is half the price of ecu... if im lazy to diy, then still can send to u right?Don...
Thanks...:wavey:
Depend lah...normally RM50~250.. (all parts replaced are new components)
Max is half da price of a ecu...
If your kaput...i will just send directions and components for you to DIY and document it..![]()
sir I have the same problem, can you help on where to place 220uf 35V caps, I cannot trace where is the positive and negative. my ecu is po8 and p30.
by the way the car starts without the 220uf 35V caps. with cel
yes, but the copper trace is damage, the positive side of the caps what component is it connected. and also the negative side.Positive is towards the connector side
at the solder side of the board, i notice that there is no connection, I am i correct?this is for the P08 jdm ecu.
I have repaired a my p27 ecu based on the attached pics you have on this thread, it really helped. the difference it that the P27 ecu have connection on the solder side of the board so i just jumper it.
I dont see it on the P08 ecu so I need to trace it on the component side of the board. the problem is im not 100% where the terminals of the caps leads to. i just have a 80W soldering iron and a pump. no magnifying device.
if you can help me with the schematic where the caps lead to what components I will be able to make the connection. I would really appreciate it. sorry I do not have pics of the board.
all the best!!!
Thread starter | Similar threads | Forum | Replies | Date |
N | DIY paintwork? | Do-It-Yourself Garage | 2 | |
M | Humble DIY Repairs On My Car | Do-It-Yourself Garage | 111 | |
T | HELP-DIY Dashboard Light Change , Honda pro please come ! :D | Do-It-Yourself Garage | 3 | |
DIY- Honda TPS in your Proton / Mitsubishi | Do-It-Yourself Garage | 14 | |
DIY-Honda EK CF Fuel Cover | Do-It-Yourself Garage | 10 |
