DIY install Voltmeter
khguan
4,818
26
Seri Kembangan
fotopic.net
hi Guys n Gals...
i bought a autogauge voltmeter few days ago.. i tot the demeter come wit a mounting bracket.. but i was wrong...
so i went around my place to find for a bracket or cup or something... found one acc. shop.. bracket rm55, cup rm45.. wah... damn so expensive.. my meter onli rm120.. not worth it to spend so much on mounting.. i dun wanto install pillars.. very chor teng cos i onli got 1 meter
this is the bracket wit the meter... not yet installed..
khguan
4,818
26
Seri Kembangan
fotopic.net
last one... closer view... de meter i stick wit black matt sticker around it.. then de steel band i sprayed it balck... some parts need touch up.. i just use black marker pen to make it black..
total cost of mounting bracket material = less than rm2.00 :lol:
time to complete installation = half a day :mellow:
altho very tiring job doing de wiring.. but satisfaction is great!! :lol: B)
khguan
4,818
26
Seri Kembangan
fotopic.net
yah.. i forgot to mention.. de power i just tap from de cigarette lighter wire.. so need to dismantel de HU console to connect de wire...
this meter got 5 wires.. 2 red, 2 black, n 1 orange..
connect de 2 red wires together... then connect de 2 blacks together.. orange no use..
so now consider got 1 red n 1 black.. u can now connect them to de power source.. red to +ve.. n black to -ve..
NiCkY7
821
Originally posted by khguan@Mar 22 2005, 22:42
erm.. i duno wor.. this meter is from taiwan i think.. it will be ok kua..
[snapback]831866[/snapback]​
hmmh... u got multimeter also? can use to test ma, tap the multimeter and on ur car, then see whether same in the reading... hihihi...
btw, y must tap at cigarette wire ar? can tap at other place? i scare it takes the reading from the cigarette wire is not so accurate....
sorry, i still very new in this... :P
khguan
4,818
26
Seri Kembangan
fotopic.net
i will check when got time..
yah i also got think bout dat b4.. well. i tap at de cigarette lighter cos easier mah.. very tired making de bracket liao..:P then somemore no need to find de ignition line.. cos cigarette power depend on ignition key wan..
well i think de voltage at there is a little lower than from de battery.. but nvm lar.. still got reading... now my battery old liao.. i think wil kaputt no long more.. so i also cant say whether de reading is accurate or not..
NiCkY7
821
[snapback]831881[/snapback]​
icic, nvm la, wait for ur news when u compared to multimeter...
cause now considering to buy this volt meter or those multimeter... i think volt meter more in fancy la, but multimeter more accurate... then battery also no need to see in everyday, one week check once also ok... so that's y still considering buy which 1... hahaha... headache... -.-"...
:P
khguan
4,818
26
Seri Kembangan
fotopic.net
well b4 i install this meter... i got use a digital multimeter measure de voltage b4.. well since my voltage is fluctuating due to old battery so i have to measure again to compare...
well.. i install this meter bcos i lazy wanto take out de multimeter n measure.. mafan mah.. then can make my car inside look better mah.. :P n i can monitor de voltage of my car all de time... B)
NiCkY7
821
[snapback]831928[/snapback]​
ya agree, take the multimeter to measure also a bit lazy when the "3 minutes hot" gone liow... haha...
but if this meter not accurate, also not so worth to spend for it la... if accurate, then is a very good buy... :D
haha, i pening in the middle of 2 road... :ph34r:
Also at this weekend's Secret M Town Malaysia is the M8 Coupe and a 4 door version M8 Gran Coupe. Both are based on BMW's newest GT range but these all-out M versions are powered by 600ps V8 twin turbo from the F90 M5.
3.3 secs / 600ps / 750nm / 4.4L V8 twin turbo (S63) / 8 speed auto M Steptronic / 4WD / 1,885kg + / M8 Coupe RM1,452,960.88 / M8 Gran Coupé RM1,455,145.25...
