DIY Honda ECU Repairs- P30 P08 P27
Dec 18, 2014
4
yar
In different car, chip without launch, all repeats(civic b20b allstock)
CEL blink like injector pulse, on full throttle no blinking
E-Tech
1,115
256
3,183
Johor
Hi..
I'm puzzled too..
WhatsApp me some pictures.
Let me see if I can see anything...
+60 19 654 7373.
Tq
Coupe-r
May 6, 2014
9
503
Tauranga
From watching the video that looks like a soldering issue inside the ecu to me.
Most likely the latch chip but COULD be the 28 pin chip.
With the ecu cover off and the car running, push down on the latch chip then the chip. See if you can get CEL to go away or come back.
That's a solid CEL though no doubt from ECU vibrating with engine running......
Connect.... not connect. connect. and so on
Bryan L
Mar 8, 2015
6
Perak
hi,
my eg can start as normal, but after start the idling rpm intermittent up and down, can felt some jerk also when change gear during drive,fuel consumption high,got black smoke. Foreman did help to put jumper check error with controller, but no error code found. He said mainly MAP sensor or ECU. I do replace with 2nd hand MAP sensor but the problem still remain. Due to no have offline ecu to test, are there any way to narrow down the problem?
ps:my english not good, hope your can get my mean.TQVM.
E-Tech
1,115
256
3,183
Johor
hi,
Mmmmm NO but u can open the ecu cover and hv a look inside.
If hv "burn" mark or brown spot high possibility it's the ecu.
You hv std engine and ecu?
Bryan L
Mar 8, 2015
6
Perak
Yup, my is std engine and ecu...I give wrong info, my is eh5 year 95.
I will check the ecu tomorrow..i also wanna find the second unit map sensor and test again..thanks ya.
Actually I new with all of this, when the third foremen told me high potential is that two item bad only I start to search online.
Do I need to do ecu reset when replace the map sensor?coz the foremen ask me jz install and see got recover or not when I found the map sensor, but I got read some write need to do after troubleshooting.
E-Tech
1,115
256
3,183
Johor
Just replace the map sensor. Does not require reset unless there error code stuck.
