a friend gave me an ecu. from what it looks like it was factory with external chip. P70. the extrnal chip. C49 C50 IC etc i know was not done by hand.
the problem is.. some one removed the chip and damaged the board. some one cut J1 using terminals of the SMD resistor was still there
he gave it to me, the ecu start. with 1.2k idle and gas smells bad.. with constant CEL. i did a CEL check, it will not blink?pulse
what i did was replace the caps that have signs of leak and re trace the copper wires to i can place the socket pin (bed) so everything is good since i have a good working ecu beside as a golden sample.
I started it again Idle was a little less than 1k but smoke smells bad and constant CEL, CEL check
do not throw codes constat cel
anyone can help. i suspect it needs the factory external eprom that was remove..
im pretty sure it came out stock with external chip..
question is for a factory ecu with external chip. does the internal Prom still work if J1 was removed.
