DIY Cold Air Intake Hose with Super Heavy Duty Industrial 3" PU Hose
sr18autech
Banned
Jun 27, 2009
209
5
Bought 3" super heavy duty industrial PU hose from Huakenny (Bought some times ago, but no time to do the CAI, until today). It's so durable and tough, and it cannot bend more than 80degree, so I have to come out with a DIY, thus this morning, did all the process below.
And the result was Superb Engine Response !
The Finished Product
Stuffs - 3" PVC Elbow, 3" PVC Pipe, Drill Saw, 3" Alloy Funnel, 3" & 5" Hose Clip, Pipe Tape & PVC Glue
Bosch Drill Kit
Circular Saw, variable sizes
Choosing the right size of the Circular Saw
Close up of the Circular Saw
Circular Saw mounted on the Bosch
The location of the funnel intended to be placed
Ready to drill
Drilling (Only took less than 10 seconds!)
Done!
The 3" Elbow and the Pipe
The 3" Heavy Duty Industrial Flex Hose
Fitted perfectly
Applying PVC glue
Attaching the elbow to the flex hose, with a 3" hose clip
Elbow in place, fitting the 3" Aloy Funnel
Wrapping the Aloy Funnel with white tape
Fitting the Aloy Funnel to the elbow
Very-very tight fit, need some effort...
A view from inside
Fastened the 3" flex hose to the airbox
Airbox connected to the flex hose
STOCK engine bay, hehe
Be sure, to make the CAI airtight, amazing effects will happen.
PS: They are ppl debating whether it will suck debris or water into the CAI n damages the engine, but HEY, if there's flood or really dusty/sandy area, everyone is SMART enough not to drive over those places.....right ?
Adios :)
loose_end
3,649
197
Malaysia
Nice nice work ..but but .. why did you drill at the side ??
loose_end
3,649
197
Malaysia
So , the wind can come from the side ?
sr18autech
Banned
209
5
haha, actually there are a few concerns
- Front bumper, not enough flat spread for the funnel to reside properly
- Facing front, anything could sucked inside including debris, sands, birds, squirrel and etc
- Facing front is obvios fugly
- By using an elbow facing side, during rain it prevents water from sucked into the airbox
by the way, the concept is base on my puny brain, so nothing to shout about. but the effects was better throttle respond during a hot day, especially traffic jam. tapping the pedal and the car moves :)
Sonic Thunder
333
i was planning to put it 4 my wira...on da front...was thinkin bout da rain n dust too...my fren told me to put a fine cloth on top of da filter...cover da passageway...it will b jst nice...wen its dirty...can jst take it owt,dust it,thn put it bck on...is dat ok?
sr18autech
Banned
209
5
Actually if u dont mind, go to hardware shop and buy PVC pipe connector, those 4" to 3" connectors, it's also can be used as a funnel.
How to DIY making it look "automotive" is up to your skills and creativity. No point spend so much buy aftermarket stuffs if it doesnt worth the money.
As long as the hose is 3", it really works well no matter the funnel facing side or forward.
---------- Post added at 09:57 AM ---------- Previous post was at 09:55 AM ----------
Anyway, if you guys needs a drilling, you can contact me, I can do it FREE for you, but ofcoz in return u belanja me a drink or anything....hahah !
Coz I felt shops givin a drillin n ask u pay RM30-40 is nonsense, the circular saw I bought for RM45 only, and so much size I can drill....haha
jinkl
4,624
376
3,183
water is not an issue unless its a flood
little bit of rain wont hydroclog ur engine, chill guys
we pump water injection into the intake more than droplets of water hehehe
Need some advice and view with regards to the problem i'm facing with my fuel pump.
When the fuel tank is full as indicated by the fuel indicator, car no problem. Run smoothly.
But when the fuel indicator drop to the remaining 3 bar (full 8bar), it started to choke and even when you press accelerator, i just won't go. Can't even rev. And died off. Try to restart, it won't start.
After that happen, once pump petrol to fill it up to full, no problem. What may cause such occurence...
