Need help guys..Im using honda eg and my 'check engine light' On during cruising..my car lost power when RPM reach around 3500 rpm!BTW Im using B16a engine..
no error codes normally are mechanical parts problemI once kena the problem with the distributor, with the same characteristic like TS.
But mine power lost for the whole rpm, feel like got something pulling the car from behind.
Vtec still kicking. The best part is, no error code shown.
Once the check light is on, the error code is recorded in ECU or similar device. Even it is off, ur mechanic still can retrieve the error code with proper device, janji u dont reset ur ECU, then it will be fine.Will the error code be shown only when the check light is on? Lately, when I start my car, the check light will be on and I will have to restart it. Once I restart, the light is gone. I told a mech to check this but he said he can check only if the light is on?? So, I just left it as it is. But on and off, when I start, the check light turns on. So, just restart and it goes. Don't know what's the problem.
Jakk...I once kena the problem with the distributor, with the same characteristic like TS.
