I had a wira 1.5 auto fuel injection when ever I climb up hill I press down the throttle the engine go on. Can anyone pls advise me what happen do I need to clean up the throttle sensor or ecu problem?
When full throttle do you get any other side effect like choking or stuttering? Possibly one of the sensors need checking. Also which Wira is yours? VDO or MMC?
have to check with computer lh bro.
happen to my friend wira before but his is 1.6 model.
in his case its the knock sensor which has its connection not good.
nothing isnabnormalnabt the engine running.
hi i have issue also on check engine light. the diagnose appears “isc servo valve / iac v. pos. s/circuit” . the mechanic said i need to change the TB around 380rm? do i need to change? because i read mostly issue on proton wira was sensor need to replace. thanks who will answer.
Ross Racing is committed to bringing you the industry's finest rebuilt performance and racing transmissions, custom high stall torque converters, shift kits and state of the art high performance transmission parts, upgrades and components.
At Ross Racing we strive to be the leader in every category - from late model domestic truck and passenger car automatics to high tech import performance and race transmissions.
All of our components and...
