Check engine light on
daruls
From Facebook
Oct 2, 2010
www.facebook.com
Need help guys..Im using honda eg and my 'check engine light' On during cruising..my car lost power when RPM reach around 3500 rpm!BTW Im using B16a engine..:banghead:
mADmAN
1,840
547
u need to find out whats the error code first...
best is to send to reputable workshop whos familiar with hondas to check
mADmAN
1,840
547
PJ check out avantgarde...spoon sports...
if subang dunno...u can try sri muda in shah alam... either siong service or fast autoworks
AD_EG
6,328
231
Ipoh
bro if you want can check your self also...
just need a small wire ... can jump the ecu and check the error code yourself and further diagnose what might be the issue...or you can just bring to a mech... :)
wiramivec
79
Putrajaya
i'm facing the same problem...
the differrent is after diagnose with CARMANN it shows "No Error Code"
but check engine is "sometimes" light on.
the mechanic change the "knock sensor" already.... its going better with the power lost problem but the light still on.
suspected distributor.... waiting sparepart from KL
FYI i'm using 4G92 Mitsubishi Mivec 1.6
Jakk
403
84
Selangor
I once kena the problem with the distributor, with the same characteristic like TS.
But mine power lost for the whole rpm, feel like got something pulling the car from behind.
Vtec still kicking. The best part is, no error code shown.
huakenny
LB Performance
9,126
240
Kota Kinabalu
no error codes normally are mechanical parts problem
ddv_nk12
1,228
236
663
PD
Will the error code be shown only when the check light is on? Lately, when I start my car, the check light will be on and I will have to restart it. Once I restart, the light is gone. I told a mech to check this but he said he can check only if the light is on?? So, I just left it as it is. But on and off, when I start, the check light turns on. So, just restart and it goes. Don't know what's the problem.
Jakk
403
84
Selangor
Once the check light is on, the error code is recorded in ECU or similar device. Even it is off, ur mechanic still can retrieve the error code with proper device, janji u dont reset ur ECU, then it will be fine.
If he say he only can retrieve the code when the check light is on, properly he going to jump the code by using wire or paperclip.
just my 50 sen, correct me if i am wrong. :itsme:
ddv_nk12
1,228
236
663
PD
Is it possible to see this in the laptop with SManager software? If I'm not wrong, I have seen a tab called Error Codes in it.
Anyway, I will get it checked soon. Thanks Jakk.
wiramivec
79
Putrajaya
Jakk...
so how the mech solve ur problem that time? share with me at least..
I'm facing the same problem with my mivec engine
2006 MERDEKA PROMOTION - Windows Roll Up Module
LOOK BELOW FOR THE MERDEKA PROMOTION!!!!!
Hi,
Introducing the latest cool gadget.
The Auto Window Wind Up Module.
Many of you may have been confused that this comes with the Radiostar Alarm. Sorry for the confusion but if you look at the description we used the word READY. This means all Radiostar Alarms are compatible with a Windows...
